Old 06-17-2022, 03:48 PM #1
Keppers12 Keppers12 is offline
Keppers12 is on a distinguished road
Dome light circuit
Due to a project got bad, I need to replace the dome light/map light circuit on my 2008 Toyota 4runner that runs between the headliner and the car, down to the ECU. Some of the wires are fried and as a result I have the relay pulled to keep the car from burning.
Apparently Toyota does not make the part, but I found a wrecking yard that has a 2008 Toyota 4Runner that said I could come pull the wires I need for about $30.
Does anyone have experience doing this? It seems like a bit of a pain, but doable. I'm assuming it will be plug and play for the most part on the dashboard in of things.
Thanks for any tips!!
Keppers12 is offline   Reply With QuoteReply With Quote
Old 06-18-2022, 04:47 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho has a spectacular aura about riceandpho has a spectacular aura about riceandpho has a spectacular aura about
riceandpho's Avatar
need to take the headliner down to trace your wires. look at some of the sound deader threads. you see the wires are glued onto the headliner. i wonder what you did that cause a small fire?
Sound Deadening and New Audio Setup
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK LTS pads F+R, Stoptech slotted rotors and stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 06-18-2022, 08:42 AM #3
Thanks for the great ideas. I was trying to tap into the atypical wires in the dome light circuit for some silly footwell lights. When it didnít go well, I tape them off and was going to come up with a new plan. While I was working on something else, the headliner wires started smoking!👎
Old 06-19-2022, 02:44 AM #4
riceandpho's Avatar
riceandpho's Avatar
@Keepers12 did the positive at the dome grounded out? i only use external relay and harnesses, you just use negative trigger, i hope you read ja website on his mods, maybe you can just take your headliner out and trace the burned wires and find that short.
dome , light , part , toyota , wires
Batt drain on Dome Circuit on a 2K 4runner Hunter 3rd gen T4Rs 22 02-28-2022 03:13 PM
Tapping in the high beam circuit for aux light JWaldz 3rd gen T4Rs 23 03-18-2020 01:33 PM
Check engine light, vsc light, traction light all on after a short circuit mikeng 4th Gen T4Rs 4 01-01-2018 07:54 PM
Help dome light circuit albaboun 5th gen T4Rs 13 12-10-2016 10:57 AM
Dome circuit Electrical Problem bmackey Problems & Warranty Issues 2 12-28-2007 03:40 AM
