06-18-2022, 11:23 AM
Real Name: brian
Real Name: brian
Gibson exhaust installation issues
Hi all. Just got a gibson exhaust with the ceramic tips for my v8 4runner. For the life of me I can't get it to line up properly. The over the frame pipe keeps hitting the frame. No matter what I do it does not stop hitting the frame. I removed the hangars, used band clamps, rested a pad under the pipe to keep it positioned while I tighten everything up. Nothing works. Anyone have these issues?
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
06-18-2022, 12:18 PM
Real Name: Ron
Real Name: Ron
I'd call Gibson and let them know, maybe you got a mis-bent pipe somehow.
But on the other hand, some aftermarket exhaust systems do not line up perfectly and "malletizing as necessary" is required!
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
06-18-2022, 12:26 PM
Are you able to post some pics? that could help someone here to help you diagnose the fitment issues
06-18-2022, 01:29 PM
Real Name: Dillon
Real Name: Dillon
I’d recommend reaching out to them. Pipes aren’t always the way they should be out of the box. Dont be afraid to do some custom fitting as well
07-07-2022, 11:20 AM
Gibson install
I'm using the dual side exit kit. It was rubbing/vibrating in a few places, but was due to 300k mile mounts. I replaced all the mounts and noises were gone.
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
07-07-2022, 06:11 PM
Real Name: brian
Real Name: brian
Sorry for the late reply. Took it to a muffler shop( got screwed on the price ) but i needed it done and it's all set. they readjusted it and welded the 2 piece tailpipe.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
