Old 06-23-2022, 09:44 PM #1
Bigshankhank Bigshankhank is offline
Real Name: Tyler
Bigshankhank is on a distinguished road
Real Name: Tyler
Right Side Ladder
I recently acquired some body damage on the right rear quarter just above the bumper cover on my 08 and figured I’ve been wanting to put a ladder on it, why not mount it there and it can hide the dent. Window seal is still good, door seal is still good it’s purely cosmetic. A quick googling shows only rear-mount ladders, does anyone know of one that mounts to the side, the right (passenger) side specifically?
2008 4Runner SR5 V6 4WD
Bigshankhank is offline   Reply With QuoteReply With Quote
Old 06-23-2022, 10:11 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
My best guess is that you would have to have it custom made, all ladders I have seen are mounted on the rear, and for a good reason, mounting one on the side of a vehicle puts it into a possible collision with other vehicles.
2004 Limited V8
Old 06-24-2022, 08:44 AM #3
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
you're not going to find an off-the-shelf ladder that isn't for the rear. Custom fab is going to be the only way to go. What are you running for a bumper and roofrack? Also, what is your plan on attaching the ladder to the rig? I don't think the quarter is strong enough to mount a ladder to if you're actually planning on using it. if you mount it to the bumper, which would be preferred, you can't tie into the body since there is movement there when you're off road. I guess It probably wouldn't really hurt anything, just put some strain on the attachment points.. but yea, something to think about.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 06-24-2022, 08:47 AM #4
I did come across this from earlier, just as a visual reference. New Southern Style Speed Rear Bumper Prototype Installed
but whatever you do... don't have a floating 4 foot ladder only bumper mounted if you plan on doing any sort of off-road near trees. That is a busted quarter glass waiting to happen.
Old 06-25-2022, 05:35 PM #5
Real Name: Tyler
Real Name: Tyler
The thinking was to get an aluminum bumper with eye lugs along with a proper roof rack with lugs to match and mount the ladder between them. I see overlanding rigs with fuel and water tanks mounted outside the rear quarter windows, not much different if the profile is kept tight.
Old 06-25-2022, 06:00 PM #6
SurferUK's Avatar
SurferUK SurferUK is online now
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
I found this but can't give you any details, I just wanted to see the requirements to fit a rear ladder, it sounds cool!
I really dig this ladder | 4runner, Toyota 4runner, Toyota 4runner trd
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is online now   Reply With QuoteReply With Quote
Old 06-25-2022, 10:21 PM #7
Real Name: Tyler
Real Name: Tyler
Dude that’s perfect! Took a little digging through the Pinterest links but I got there in the end.
Ladders — Gamiviti
Thank you!
Old 06-27-2022, 09:36 PM #8
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
The main problem with mounting to both the bumper and the roof rack is that the body/roof is floating on the frame and bumper would be solid mounted to the frame. Despite these frames being fully boxed, the frame itself still does flex a decent amount relative to the body. This would lead to a fatigue failure of the roof mounts of the rack fairly shortly.
As far as profile, depends on where you're wheeling. Any extra gizmos on the side are generally gonna be tree snaggers in the midwest and east, but out west you'd be fine
y=mx+b is offline   Reply With QuoteReply With Quote
Old 06-28-2022, 10:02 AM #9
^^ that was my point too.. If you're not planning on doing any sort of wheeling you probably wont see much flex. However, I can tell you with certainty that I can quite easily close up a 1/2-1" bumper-to-fender gap when fully flexed on an obstacle... the body with relation to frame moves ALOT.
Having overlanding gear stuck to the side overhanging the fender is one thing. I'm running a similar setup with rear molle panels over the rear quarter glass. One side houses my fuel the other my traction boards. I have snagged these on trees, it isn't ideal for tight trails but use for regular camping trips. My hole point on a floating 4ft ladder hanging up from the bumper and terminating AT the quarter glass is that even a minor lean onto a tree or dirt v-notch will guarantee a busted out glass.
Old 06-28-2022, 05:53 PM #10
Real Name: Tyler
Real Name: Tyler
According to the details on the product page, the upper connection point (at the rack) allows for some flexibility to accommodate some body vs frame movement. Maybe not 1-1/2” but they acknowledge the risk, and since it’s only held by clevis pins it’s easy to remove if the rig does get into some tight or rougher trails.
In terms of end use, my Runner is my daily commuter with some jaunts off-road on local open field trails as well as camping and canoe/kayak trips, this isn’t a hard trail rig by any stretch. Even having Molle panels & accessories inside or out is more than I am trying to do.
Old 07-07-2022, 11:22 PM #11
iamatt iamatt is offline
iamatt is on a distinguished road
We did this but its just a beach vehicle. Mount to the existing roof rack.
Sent from my Pixel 3 using Tapatalk
iamatt is offline   Reply With QuoteReply With Quote
door , good , ladder , seal , side
FS: Rago Fabrication Ladder Accessory Mount (Gobi Ladder) - Atlanta, GA - $50 Shipped kevsMAGNETO4R For Sale: T4R Items 1 01-27-2019 04:49 PM
Hatch ladder for PASSENGER side? Agent_Outside 5th gen T4Rs 2 10-29-2018 09:52 PM
Side ladder happypizza 5th gen T4Rs 3 07-10-2017 11:04 PM
Ladder CATy Ladder Rack laddercaty Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-11-2009 03:17 PM
