Old 06-27-2022, 11:57 PM #1
CarlosV CarlosV is offline
Real Name: Carlos V.
CarlosV will become famous soon enough
Help with fuel pressure question. 2003 V6
I am trying to figure out why recently I get occasional longer cranking times.
The fuel pressure goes to “0” inmediatly after turning off the engine. (Running is at 40-41psi.) Is this definitely abnormal? No obvious leak…
Thanks
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
CarlosV is offline   Reply With QuoteReply With Quote
Old 06-28-2022, 09:37 AM #2
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
looks like your fuel pump is on it's way out. fuel pressure should slowly decrease.
Thanks
4r-4ever is offline   Reply With QuoteReply With Quote
Old 06-28-2022, 11:31 AM #3
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
You likely have a bad fuel pressure regulator allowing pressure to just blow out the return line (or a faulty pump doing the same).
The pressure regulator should be easy to test, just block off the return line and do a fuel pressure test, if it's still dropping to zero then it's probably back feeding through the fuel pump.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 06-28-2022, 08:40 PM #4
Thanks 4r. What in the pump will not hold pressure, when the car&pump is off?
Old 06-28-2022, 08:44 PM #5
Thanks BWInc. Will check pressure regulator.
Back feeding thru the pump back into the tank?
Old 09-22-2022, 10:13 PM #6
Thanks a lot BlackWorksInc. You were right. Changed the new Denso pump (it may well be a fake Denso even it looks very well constructed, like OEM) back to my original OEM pump after putting a new pump motor on it and that was the end of immediate zero pressure after turn off and no more occasional long cranks.
Question: problem in the pump allowing return into the tank is more likely localize at the junction of the pump and the plastic carcass where fuel line takes off? O-ring?
Thanks again.
engine , fuel , leak… , pressure , turning
Fuel pump or fuel pressure regulator? ggrant Problems & Warranty Issues 4 09-29-2023 10:54 AM
'19 5th Gen Fuel pressure/fuel system mugenrios2k Engines / Suspension / Wheels / Tires / Audio / Accessories 2 03-25-2019 08:38 AM
Fuel pressure rodsrunner 4th Gen T4Rs 0 08-04-2018 01:30 PM
97 4Runner fuel tank building pressure/ wont take fuel Yotaoffroad27 3rd gen T4Rs 4 10-06-2015 10:34 AM
Too Much Fuel Pressure please help osborgo Classic T4Rs 6 02-10-2010 07:31 PM
