06-28-2022, 09:28 AM
bilstein 5100 rear snapped
just saw this randomly. am visiting beach so not a lot of repair options. thinking back, truck seemed to bounce a little longer on big highway bumps. is it crazy to drive 5 hours home on this in a few days? i doubt i could get replacement shock in time anyway and i don't want to pay for two shocks and two repairs (DIY'd the original install [with FJ coils] with help but not in a place to do that anymore).
i can replace just the one right?
Imgur: The magic of the Internet
2008 SE V6 4x4, Bilstein 5100's (1.75 in front), FJ springs, Cornfed 1" rear spacer, SCS Stealth 6, Toyo OC AT2 265/70/17, HID 4300k, Plasti-Dip front grill, Flowmaster 50 SUV
06-28-2022, 10:25 AM
you can definitely drive it with broken shocks.
06-28-2022, 12:35 PM
Real Name: Reinout
Real Name: Reinout
Looks like it got over-extended.
Yes you can drive it that way but as you noticed it'll be bouncy.
The spring is what sets the "ride height".
I would remove the broken shock no matter what you do so that you don't cause any potential damage to anything else under there like brake lines.
If anything: find a cheap cheap cheap replacement for the meantime so you have some semblance of shock control.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
06-28-2022, 03:30 PM
I would at least call the local salvage yards and see if they have one you could throw in there for your drive home. Definitely remove the old one regardless like someone else mentioned above so you don’t damage anything around it.
2004 SR5 V8 AWD
06-28-2022, 09:16 PM
thanks guys!
07-16-2022, 10:24 AM
Turns out some rust developed around the thread and then the shock separated there. Seller says Bilstein won't cover since it's been 9 years and there's rust everywhere, but a lot of those spots aren't rust, just oil/dirt I'd expect them to last longer but oh well, already bought and installed the replacement. We'll see how the others do.
07-18-2022, 12:49 AM
not sure if they will warranty the shock, but can you thread that part back in?
Warranty - BILSTEIN Off-Road
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
07-18-2022, 07:14 PM
OT - Do you have extended bump stops installed?
I can't tell from the pic..
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
