Old 07-09-2022, 09:40 AM #1
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
bilstien B12 springs
hey guys, I'm planning to change out the Moog FJ springs I have in the rear to some Bilstien B12 36-281824, since I am going to take out the airbags and replacing the jounce bumper too. I figure I want better fitting springs.
I order the 36-281824 hopefully these are going to give me what the Moog gave me, with the Moogs, i think it was 36+ on the driver side rear and 38ish on the passenger side, also the pass side spring never seated correctly.
plus I have a constant 200 pounds or so from the rear battery and sub setup.
should I order the 36-281817 over the 36-281824 ?
will it be a perfect match to the old springs since I also have constant weight.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 07-10-2022, 09:53 PM #2
riceandpho's Avatar
riceandpho's Avatar
got the springs , they are measured at 16 inches give or take, im waiting for the other replacement parts from partznet so I can install the work once, maybe i should do it now incase i want to return the springs for the shorter ones.
Old 07-11-2022, 01:53 AM #3
riceandpho's Avatar
riceandpho's Avatar
springs are installed, waiting for my replacement spring insulator to come so I can take out the airbags with a hole.
measurements 37ish on driver rear and 38 3/4 on the passenger rear.
little bit over half tank of gas, 275/55/r20 tires at 40psi. sub and amp and rear group 31 battery total weight is a little 200 to 210 pounds, original spare 265/65r17 is still under the truck.
so far its about 1 inch higher than the moog 81081 with 40-50k miles?
the bilstein b12 springs measure at about 16 inches. also it fits so much better in the bottom spring perch.
took it out for a drive and it is firmer. the moogs were soft. I can tell the bounce is less. hit the speed bumps and it feels firm and better.
glad I went with the longer springs, I wonder how much it'll settle. might have to adjust my lights a little bit.
36-281824 , bilstien , rear , side , springs
Bilstien 6112 springs Guru6022 For Sale: Suspension/Wheels/Tires 3 01-20-2022 05:27 PM
Moog FJ springs + Bilstien 5100 twa318 4th Gen T4Rs 8 02-23-2018 04:03 PM
FS: Bilstien 5100 + front OME 884 + Rear Lift Springs. {Mayer, MN} m-m-93 For Sale: Suspension/Wheels/Tires 7 01-19-2017 12:57 AM
