Old 07-11-2022, 09:26 AM #1
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Aftermarket Bumper put a hole in my AC line
Got to the end of a week of fun wheeling in the Silverton/Ouray/Telluride area (did black bear rd!), and realized my AC liquid line was spewing everywhere. While it was still running cool, I immediately killed the AC, as the line was compromised. After a hot summer drive across the NM desert, I need to fix my AC system.
First a PSA to those with aftermarket bumpers. Make sure there is no contact between the AC lines and edges. It will destroy them. Learn from my pain.
Some questions:
1) do I replace the liquid line or do I patch it? A new line is 170$ online, as this appear to be one of the lines that doesn't have a generic version.
2) Are there other things I need to replace while I'm at it? I know I need to replace the desiccant. My AC system was working fine, but one way or another its drained now. Wondering if I should take the opportunity to replace anything else.
3) Any opinions on having a mechanic vacuum and fill the system vs buying the equipment from harbor freight? I believe I'd need the valve kit and a vacuum unit, which is about 150$.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 07-11-2022, 11:10 AM #2
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Thanks for the PSA and sorry this happened on a trip. I added some foam between my SW bumper and the hard line but this prompted me to check in on it.
As for patching vs. replacing, I'd personally swap it for an OEM part. I've never patched an AC hardline but for the inconvenience (and cost of repair/refill) of having the system go down on a trip, $170 seems tolerable. Maybe others have experience with patching. And yes on replacing the desiccant bag.
Regardless of who does the recovery/refill, I'd add in some dye to help make chasing subsequent issues easier since the system has been opened.
eleven14 is offline   Reply With QuoteReply With Quote
Old 07-11-2022, 01:37 PM #3
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
I've always been amazed at some of the exposed lines I have around the coastal offroad bumper.. There is definitely some risk there. I'm assuming yours probably happened not from a single impact/pinch but rather contact it was making all the time and the body flex rubbing through the line? Or no?
With regards to patch or replace.. I bought my rig wrecked in the front end, and the AC line was pinched/broken. Instead of replacing the complete line I gave an amazon patch kit a try since it was significantly cheaper and 2 years almost to this day it is still holding and blowing cold AC.
Unless you plan on doing some of of your other rigs I would elect to have someone with equipment do it for your vs buying cheaper equipment to DYI. Luckily for me I had a buddy who rebuilt quite a few salvage title cars so he had his own small setup and was able to charge my system for me.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 07-11-2022, 02:02 PM #4
Which patch kit did you use? One of the ones with the length of rubber hose? Or just the double nut setup?
Issue was created by the rubber line contacted the edge of the bumper where it passed through. Vibration basically rubbed it through.
Old 07-11-2022, 04:25 PM #5
It's the one with the rubber hose that clamps in place. I'll see if I can dig up what I got.
Old 07-11-2022, 04:32 PM #6
Can’t find where I got it but this is what mine looks like
Old 07-11-2022, 05:00 PM #7
Bassturd's Avatar
Bassturd Bassturd is offline
Bassturd has a spectacular aura about Bassturd has a spectacular aura about
Bassturd's Avatar
Up on the mountain we are always blowing through hydraulic hoses and we just go to a house of hose and have them make us exactly what we need. I’m not sure if they do AC lines but it’s worth asking if your in a pinch or dealer doesn’t have one in stock.
2004 SR5 V8 AWD
Bassturd is offline   Reply With QuoteReply With Quote
Old 07-11-2022, 05:22 PM #8
This is exactly what I just bought. Going to give this a try, as it may give me some options for rerouting the hose a bit to minimize future damage.
Also going to put some hose around the other lines where they might rub to prevent this from happening again -_-
Autozone will rent me the manifold gauges and the vacuum, and my system is already emptied, so I'll use that to make sure it holds vacuum and then refill again.
Old 07-11-2022, 05:44 PM #9
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
If you're going to refill the system make sure you get a kit that has the oil with it, I'm sure you lost some of the oil that was in there.
I forget how much oil should be in the system, but I think it's about 1 1/2 ounce or so but I could be way off...do the research so you get it close to the correct amount, too little is not good and too much it also not good, but there's a little wiggle room in what is too much.
2004 Limited V8
Old 07-11-2022, 06:09 PM #10
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
I have the same True North Fab bumper as you. I bent the hard line back and covered it with rubber hose just in case.
I’ll definitely check this frequently.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 07-12-2022, 01:41 PM #11
Yeah, I lost some oil, but not a ton. I'm guessing I just lost whatever was in the line for the most part. What I'm seeing online is most of the oil addition occurs when you change out one of the actual components instead of hoses.
My plan right now is to add a bit with the UV dye in it.
Old 07-12-2022, 01:42 PM #12
Mine broke where it goes down into the condenser in the lower part of the bumper. Not where I expected it to break honestly. Going to cover the rest with rubber hose to make sure nothing else happens.
Old 06-03-2023, 03:19 PM #13
category_theory category_theory is offline
category_theory is on a distinguished road
Where did you buy this??!
category_theory is offline   Reply With QuoteReply With Quote
Old 06-08-2023, 08:47 AM #14
I found mine on amazon.. and can confirm that almost 2 years since the original repair and my AC still does fine and hasn't leaked.
This is from my purchase history: Amazon.com
Old 06-08-2023, 10:51 AM #15
Mine isn't leaking either yet. Not a bad kit.
Whenever I have to redo the AC system, I may replace with a new hardline, but until then this is a great option.
line , lines , liquid , replace , system
WTB Toyota 4Runner Front Bumper Fog Light Hole Covers 1999-2002 Auce Want to Buy/Trade 1 03-18-2022 01:09 PM
Brake Line Question (OEM vs Aftermarket) ArmArak 3rd gen T4Rs 6 06-17-2020 09:00 PM
Drill big honking hole in rear bumper for trailer wiring connector?! bass-o-matic General Discussions 9 08-13-2016 01:15 PM
Butt hole moved after Body lift (Spare tire access hole) KSWAY 3rd gen T4Rs 3 03-13-2013 11:09 PM
Need help installing line converter for aftermarket amplifier gkatmar Engines / Suspension / Wheels / Tires / Audio / Accessories 5 06-22-2008 03:38 PM
