Old 07-14-2022, 09:08 AM #1
Rsbhunter Rsbhunter is offline
Rsbhunter is on a distinguished road
Mystery battery light
Is have researched this to death!!!! Went out one morning, went to go out of town, and my 2006 Sport battery light is on, along with the abs lights, Trac control, etc on the right side of the speedo dial. Drove it around a couple blocks to see if any went off. Truck had been fine last time I drove it probably a week before. After checking, I found the battery voltage was 11.8v, replaced battery with new one. Light still on. Pulled alternator, had tested, found bad. Bought reman "Remy" alt, installed, and shows 14.0-14.2 while running, battery @ 12.8 sitting. Battery light STILL on. I've checked fuses under hood and dash, all good. Sorry for long post, but wanted to give all the details...by the way, the abs, And other lights were from the right side speed sensor wires being pulled apart! I don't 4 wheel this 4 runner( im old) so that happening is another mystery. Any direction I can go in or check would be a great help....does a batt light need to be "reset, I disconnected the batt, touched cables together, waited 15 min, and reconnected... light still on!!!! rsbhunter
Rsbhunter is offline   Reply With QuoteReply With Quote
Old 07-15-2022, 10:30 PM #2
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Originally Posted by Rsbhunter View Post
Pulled alternator, had tested, found bad. Bought reman "Remy" alt, installed, and shows 14.0-14.2 while running, battery @ 12.8 sitting. Battery light STILL on. ! rsbhunter
I sort of answered this to you in another post but in that post I don't remember you stating you had replaced the alternator. All the same except for on detail. With the key on, engine off, if you disconnect the alternator connector, the light should go off, then back on when you connect it. If it doesn't go off, then the circuit is shorted to ground, if it does, AND it comes back on when connected...then your reman Remy is No Goody. Hope that clears it up!
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 07-20-2022, 09:52 AM #3
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
i agree, the new alternator is bad if the battery light do not turn off.
4r-4ever is offline   Reply With QuoteReply With Quote
battery , drove , light , pulled , side
Battery Light + Whine + Low Idle + New Battery TT4RLtdV8 4th Gen T4Rs 23 06-17-2022 09:51 PM
CS144 to solve battery mystery tyr0981 3rd gen T4Rs 25 11-01-2014 09:48 AM
Mystery Light gaterose 4th Gen T4Rs 4 05-17-2013 08:10 AM
2000 TR4 Map light Mystery???? Bob_VT 3rd gen T4Rs 3 11-19-2007 01:35 AM
