Originally Posted by Rsbhunter
Pulled alternator, had tested, found bad. Bought reman "Remy" alt, installed, and shows 14.0-14.2 while running, battery @ 12.8 sitting. Battery light STILL on. ! rsbhunter
I sort of answered this to you in another post but in that post I don't remember you stating you had replaced the alternator. All the same except for on detail. With the key on, engine off, if you disconnect the alternator connector, the light should go off, then back on when you connect it. If it doesn't go off, then the circuit is shorted to ground, if it does, AND it comes back on when connected...then your reman Remy is No Goody. Hope that clears it up!
