Noob here. Just picked up a nice 2005 Limited. On the left (drivers) side the turnsignal/DRL housing is cloudy, and after polishing, it is hazed on the inside?
How does this unit come out? I looked behind it and can't find out how it is attached. Does it just "pop" out? I did a search and all I found was bulb replacement, which is very obvious.
Also any leads on a reasonable replacement besides my local dealer?
I will eventually kill my DRL's as I hate them!
Thanks for the help guys!
just look under bumper closer, whole assembly held with 3 screws I believe. Easy to pull out
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
You can access the fog, and the front turn signal lamp assembly from the fender lines infront of the wheels.
also, here is a PDF attached on how to replace the turn signal...
i think you need to remove a screw and release a claw fitting.
__________________ 2017 SR5 4WD - Blistein 5100s - Cooper AT3s - HID Lows - LED Fogs 2003 SR5 V8 - Sold
Correct. Note: To remove the turn signal you only need to remove the screw closest to the bumper i.e. for the driver's side signal all that needs to be removed is the screw located farthest to the left. Then tug on the housing from the front of the vehicle while pushing from behind and it will pop out.
2017 Toyota Tacoma TRD Sport DCSB Previous
2011 Toyota 4Runner Limited 4WD
4th Gen 4Runner SR5 4WD
3rd gen 4Runner Limited
That sounds right. I will try and remove that one screw/bolt and see if it pushes out. Sometimes they realease from the front by releasing a clip or something.
Anyway, thanks for the help. Any ideas on a cheap source for an OEM part like that?
Sorry to bump such an old thread, but replacing my Turn signals now.
How in the world do you release the claw fitting? I don't see any way to get to it.
There is 1 Screw in the turn signal and 2 or 3 on the Fog. Remove them. Push fog light out and Turn signal housing will come out with it because they are connected to each other then you can seperate them. Easier than trying to push Fog out by itself
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Sorry for bumping an old thread.
I’m trying to replace both, but one side seems be stuck while I had no issues getting the other one off. I removed all 3 screws as shown in the earlier pic and tried to push out from back and pull from front.
Did you ever get this taken care of? How did it go? I want to try this today or tomorrow...
I am at the point where I have the turn signal fog light combo removed, but I can't figure how to separate the them from each other. There is a tab pushed through a slot that keeps them together, and this link here will help w that: Front turn signal lens body replacement
Oh. I had actually cut the original and when I put the new one on I realized you can tilt it (up/down with it facing you) and pull them apart, the fitting/tab keeping them together is like a hook.
