Old 07-19-2022, 12:42 AM #1
Jayson44's Avatar
Jayson44 Jayson44 is offline
Jayson44 will become famous soon enough
Jayson44's Avatar
rear wiper washer motor not working
my rear washer pump stopped working, so I bought a new one. installed it today and...nothing. so I swapped motors and it seems the wiring doesn't work. I checked the fuse for the rear washer and it's fine, even replaced it to make sure.
what should I check next? the front washer works just fine.
J.
05 v8 Sport - K&N air filter - Toytec Ultimate front + OME 3" rear - JBA HD UCAs - Spydertrax spacers - 35" Kenati Trail Hogs - Vors v37s
Jayson44 is offline   Reply With QuoteReply With Quote
Old 07-20-2022, 02:41 PM #2
brent_19 brent_19 is offline
brent_19 is on a distinguished road
check the wires going from body to door inside of rubber boot
brent_19 is offline   Reply With QuoteReply With Quote
Old 07-20-2022, 03:22 PM #3
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
out of curosity does your back window still work???
daprotege5 is offline   Reply With QuoteReply With Quote
Old 07-21-2022, 12:07 AM #4
Jayson44's Avatar
Jayson44's Avatar
yes it does. along with the rear wiper.
J.
Old 07-21-2022, 12:07 AM #5
Jayson44's Avatar
Jayson44's Avatar
in the front or on the rear hatch?
J.
Old 07-21-2022, 02:24 PM #6
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Have you tested the wires that connect to the pump to verify there's no power? I understand it seems there's no power since neither pump works but if your current pump is dead and the replacement happened to be a dud too...yeah, unlikely to say the least, but testing would tell you for sure that the wiring is the problem.
FWIW, I take the post above to mean checking the wires through the boot leading from the body to the hatch. Then I'd trace them from there to the pump to be sure there's no damage, crimping, etc.
I wish you the best in sorting this out. These are the kinds of things that drive me crazy.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 07-21-2022, 04:49 PM #7
Jayson44's Avatar
Jayson44's Avatar
I tested both the new and the old pump on the front pump wiring. they both work. so the old pump wasn't actually dead, just the wiring for whatever reason.
J.
Old 07-28-2022, 09:23 AM #8
J.
at the top of the rear door is the one that everyone talks about..
Kind of going through something similar myself, where my window stopped working when i changed the rear wiper arm which now also doesn't work. So my problem is different, but from what I've seen about the rear hatch door failures, that is a good starting point. Years and years of flexing, a single wire could've broke. I can say that with my frozen motor (wiggle's occasionally) the pump still works as it should. So in my case, I suspect the motor isn't parked fully. For you, sounds like a short.
fine , rear , replaced , washer , working
Rear wiper/washer suddenly not working Ray Dunakin 5th gen T4Rs 45 02-25-2024 08:27 PM
rear wiper / washer not working thholr Problems & Warranty Issues 37 01-09-2020 07:34 PM
HELP! rear windshield washer and wiper not working! myk1013 5th gen T4Rs 16 03-21-2019 10:13 AM
Rear and mirror defrost, rear washer and wiper not working 28. 4th Gen T4Rs 9 02-14-2018 11:22 PM
Rear Wiper & Washer Not Working AE1M 4th Gen T4Rs 6 09-22-2013 09:33 PM
