Originally Posted by SurferUK
Check that the cabin temperature sensor is still plugged in and not dirty. It's behind a little grille by the drivers knee. Next to centre diff lock button. Everything there was unplugged when I got mine and it had similar symptoms.
Thanks very much for that. It's precisely what was happening. The air sampling sensor and tube were attached properly to the lower dash panel but on closer examination there was no actual wire attached to the sensor. Got out the flashlight, rummaged around for the wire, found it, plugged it back in and good to go.
I mentioned that I replaced the stereo over the weekend ... must've bonked that wire loose while removing a couple of the dash panels! What a relief. Thanks again for your 100% correct diagnosis!!!
