Originally Posted by 4RunnerAquasport
That is an accurate description. Your Catalytic converters on the V8 are attached to the factory exhaust header/manifold. So when you remove them they come out together. See: Manifold/CC pic
I actually still have these, nothing wrong with them.
I ran just the Thorley Y with the factory manifolds and an old Thrush muffler for a year and 1/2. Sounded pretty good.
Now for the o2 sensor placement. The first two in the upstream flow are NOT o2 sensors. They look almost identical, but they are air/fuel ratio sensors.
If you look at the pic of mine, you'll see a small hole on the inside of the bend. Thats where the A/F sensors live. If you go with just the Y pipe and do not replace the factory manifolds, you will not need to touch them.
Behind the catalytic converter in the down stream flow are the o2 sensors. They live in the Y pipe, and will then live in your Thorley Y pipe.
Hey Aquasport, thanks a lot for the confirmation, the picture and also for that detailed summary - I'll make my own sketch based on your description; it's cool to be able to put all this information together in my head. Thanks a ton for taking the time to respond and giving me that useful information!
