Originally Posted by daprotege5
oh wait.... the whole thing is an assembly isn't it, i just can't replace the bulbs???
You can replace just the bulb. Go to a parts store and buy any H11 halogen bulb and it'll be an easy swap in just a minute or two.
If you want high end halogen, the Tungsram Nighthawk Platinum H11s are one of the better options and are under $30 on amazon.
If you want to go LED, the Hikari Ultrafocus (Eye of Megatron box) H11s are closer to $90 and are among those very few recommended sets from the tacomaworld thread.
I strongly suggest not buying any of the cheap LED bulbs on the market, most of them are pretty shitty to actually drive with. They don't focus the light at distance properly, and leave dark spots/gaps in the beam pattern up close. Both of those end up leaving you with less visibility than even the cheapest halogen bulbs.
HID kits would likely be the absolute best output, but are expensive and complicated relative to the other options, so you probably don't want to go with that either.
