Old 11-04-2018, 12:12 PM #1
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Should I Change My Transmission Fluid?
Bought my 4Runner used at about 110k and currently at about 160k. Its a 2008 v6 4x4 with the "sealed/lifetime" tranny.
Toyota service records from previous owner show no transmission fluid change. I haven't touched the transmission either. The transmission shifts with no issue.
I've been going a good bit of preventative maint on my car these past few months, and the thought of changing my transmission fluid came up. However, I'm hesitant after watching the two youtube videos below. I'd say both are reputable.
Scotty Kilmer on Changing Transmission Fluid: Don't change at all if car is old. Transmission on borrowed time. Thicker transmission fluid helps transmission function
Chris Fix on Changing Transmission Fluid: Suggests changing lifetime fluid, but not flushing. Flushing can gum up the valve body. Flushing has no downsides.
Should I change my transmission fluid? And if so flush or fill/drain?
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 11-04-2018, 12:14 PM #2
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Million dollar question is, what is the condition of the current fluid? If not terrible, I would do a pan and filter service. Forced flush is never a good idea IMO Get ready for the shit storm of a million different opinions on this topic though lol.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 11-04-2018, 12:21 PM #3
Berty_K's Avatar
Berty_K's Avatar
Lol. I changed the radiator on Friday and the transmission fluid was dark. No dipstick.
I don't do any serious towing, and neither did the previous owner.
Old 11-04-2018, 12:27 PM #4
woodman60 woodman60 is offline
woodman60 is on a distinguished road
I did two consecutive drain and fills on mine with 190K. Others will tell you to do a full flush until it runs pink through the cooler lines.
If you drain and fill, closely match the volume out to the volume you put back and you can forego the overflow process. Also, be careful as the drain plug is very easy to cross thread on the pan.
Didn't notice any change in performance, but gives a little peace of mind.
Just my experience...your mileage may vary
woodman60 is offline   Reply With QuoteReply With Quote
Old 11-04-2018, 12:28 PM #5
Real Name: Chris
Real Name: Chris
Pan and filter service is all I would personally do.
Old 11-04-2018, 12:41 PM #6
Berty_K's Avatar
Berty_K's Avatar
As in drop the pan, clean the crap, put in new filter, then reattach pan?
Old 11-04-2018, 12:42 PM #7
Real Name: Chris
Real Name: Chris
Yes. Measure the fluid lost when removing the pan and add the same quantity back in with fresh fluid.
Old 11-04-2018, 12:43 PM #8
Berty_K's Avatar
Berty_K's Avatar
Yeah, I'm leery of doing any flushing. Why didnt you go with the overflow as suggested in the FSM?
Old 11-04-2018, 12:43 PM #9
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Do the complete fluid exchange by using the in & out cooler lines at the radiator. That's not a pressurized flush, just an exchange while the fluid is normally circulating.
Your transmission was designed to use a specific fluid, and the stuff in your high-mileage transmission is completely out of spec at this point.
You'll probably notice smoother shifting, better mileage, and your transmission will last longer with proper fluid and not that old, dirty stuff that's in there now.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 11-04-2018, 02:24 PM #10
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Did you see Scotty Kilmer’s episode on “lifetime” transmission fluid? Change it by full exchange (not forced flush) as others have recommended. My local dealer did a full exchange for $179 or so. Thought that was fair since the fluid alone was $100+.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 11-04-2018, 02:28 PM #11
Whiskey & Wrenches Whiskey & Wrenches is offline
Real Name: 2004 SR5 V6 4WD
Whiskey & Wrenches is on a distinguished road
160 K on the odometer is not that much for these vehicles. I would definitely change the transmission fluid. Without changing it, at some point down the road you are guaranteeing you will be replacing the transmission and that will be an expensive job.
2004 SR5 V6 4WD
Whiskey & Wrenches is offline   Reply With QuoteReply With Quote
Old 11-04-2018, 03:09 PM #12
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
my '07 v6 has 202k miles w/original transmission fluid. spoke to two dealers about it. one does not have the setup for a full replacement, so recommend drain and fill. the other does have the ability, recommended full replacement (not a force flush, neither recommended that).
both said they do not recommend dropping the pan. the filter is a metal mesh screen. they only drop the pan if there is a leak.
so, find a shop that will do a full replacement, do not drop the pan (unless leaking).
cost depends on location. here, north of boston, retail runs about $250 before discounts. unlike oil changes, this only will get done about every 100k, so i don't mind having the dealer involved (the fluid alone is about $100). just use toyota ws. this is what the manufacture recommends.
rwh963 is offline   Reply With QuoteReply With Quote
Old 11-04-2018, 05:15 PM #13
Morphyne Morphyne is offline
Morphyne will become famous soon enough
I have an 05 V8 with 140k miles and an 07 V6 with 216kmiles. I've changed both of the files dropped the pans and done three full fluid exchanges. I change every 50k miles starting at 150k on the 07 and 100k on the 05.
So with that experience listed in will say this. You absolutely should change your fluid. Don't bother changing the filter. It's just a metal screen. The only reason to drop the pan is to check the magnets and clean out the sludge. Dont use a torque wrench. Using Valvoline max life is just fine. And drain and fills are just lazy.
Morphyne is offline   Reply With QuoteReply With Quote
Old 11-04-2018, 06:06 PM #14
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Why do you say to not use a torque wrench??
2004 Limited V8
Old 11-04-2018, 06:22 PM #15
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
I bought my truck with 136k on it. No records of tranny service, so I drain and filled a total of 1 gallon over the period of a weekend. Truck drives fine, and I have since gotten into the practice of doing a drain and fill every 10k since it's easy to do and I'm already under the truck greasing the drive line
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Should I change transmission fluid or not? bgravy 3rd gen T4Rs 34 04-11-2020 02:12 PM
Transmission Fluid Change? chetJ 5th gen T4Rs 8 05-06-2014 08:22 AM
Transmission Fluid change $$$ ToolmanJohn Maintenance/Detailing 5 07-03-2012 05:02 PM
Transmission Fluid change???? jesman1484 3rd gen T4Rs 1 11-01-2007 07:49 PM
Transmission fluid change BadHabit Maintenance/Detailing 2 03-26-2005 04:46 PM
