Old 07-30-2022, 11:34 PM #1
DASYOTA DASYOTA is offline
DASYOTA is on a distinguished road
4.7 V8 High output Alternator Upgrade
I've finally got around to upgrading to a H/O alt for my sound system, so I got a 250 amp Brand X with a regulator bypass to bump my charging up to 14.8.
[IMG]alternators[/IMG]
The issue you will run into if you go this route is the plug sticks out and hits the power steering pump bracket which you can see in this video (not my video) https://www.youtube.com/watch?v=fW6GBgoMkq0&t=353s
So to solve this issue instead of grinding down the bracket like they did, I decided to trim down the connector and direct solder the leads.
As you can see the alternator pulley is significantly smaller so I got 2 smaller serpentine belts.
Here is What Rock Auto recommends for a stock replacement the ACDELCO 6k882
[IMG]882[/IMG]
Here's 1 size shorter as per their online catalog (6K878)
[IMG]6k878[/IMG]
And the next size down (6K876)
[IMG]6K876[/IMG]
The Issue I'm running into is when I installed the shorter belt, I am getting a pulley squealing sound I'm assuming slippage. My charging voltage goes from 12.2 (not charging) for the first 10 or 15 seconds, to 15 volts where it should be then up to 16/17 volts and bounces around. I'm assuming because of slippage or an issue with the tensioner.
I need some help from someone to diagnose the issue, is there any reason why these belts shouldn't work if they are the same amount of ribs as stock just a bit shorter? Or is it possible the tensioner is going out with the new belt loaded on?
It seems like the regulator/wiring is ok, because when the belt finally catches on it was hovering perfectly at the set voltage 14.8.
I've done the big 4 upgrade to 1/0 gauge for grounds to the body/engine/frame and alternator to battery.
I also just got a brand new interstate 24F AGM which is resting at 12.6 when I tested it. Any ideas?
DASYOTA is offline   Reply With QuoteReply With Quote
Old 07-31-2022, 01:15 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
maybe tensioner, but having that 14.8v cold voltage is kind of high.
im no expert, but contact your alternator company. thye should have some basic troubleshooting.
or return your alternator for another brand? im using mechman on the v6.
are you running the shortest belt? 87- 87.5 ?
Please Wait... | Cloudflare
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 07-31-2022, 01:20 AM #3
Thanks for the response, I may have to get it swapped back to the stock regulator. The reason I wanted to go to 14.8 is so I can run lithium to support 6k.
Did you have to get a shorter belt for your Mechman?
Old 07-31-2022, 02:22 AM #4
riceandpho's Avatar
riceandpho's Avatar
yes, shorter belt.
i found the gates green heavy duty belt for my application.
i also changed my tensioner 2 years ago, it was fine with the original one. so i probably didnt need to change it out.
Old 07-31-2022, 09:19 AM #5
Wile Kyote Wile Kyote is offline
Wile Kyote is on a distinguished road
Not to sway from OP but do you have more info on this? Contemplating upgrading to HO alt and running a new wire off battery to power a new fuse block for future accessories/lights.
Wile Kyote is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 10:09 AM #6
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Get the Gates FleetRunner belts.
I had an AC Delco belt and it squeaked horribly right out of the box. The Gates Fleetrunner hasn't made a squeak in 3K miles.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
alternator , belt , charging , issue , shorter
High Output Alternator Jrrrrr 5th gen T4Rs 1 06-07-2022 12:53 PM
WTB 4th gen 4.0 High Output Alternator Rocket61 Want to Buy/Trade 1 02-28-2016 10:59 PM
WTB 4th gen 4.0 High Output Alternator Rocket61 Want to Buy/Trade 0 09-26-2015 02:50 PM
High Output Alternator? SixxiA Classic T4Rs 1 10-04-2008 01:21 PM
High output alternator Erich 4th Gen T4Rs 3 07-27-2008 02:44 AM
