Old 08-06-2022, 11:41 AM #1
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Battery Issue?
I'm on my second battery from Costco, the first failed in less than 90 days and the replacement has some strange condensation/moisture forming on the top after about 18 months.
Is this normal? I'm having zero issues but noticed it while doing some other maintenance.
eleven14 is offline   Reply With QuoteReply With Quote
Old 08-06-2022, 01:37 PM #2
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
That's battery acid seeping from the battery. You can verify this by making a thin paste of baking soda and water, applying it to the wet spot, and watching for bubbling action. This is a common warranty claim condition.
Verify your charging voltage. If it exceeds FSM spec of 14.2, then there's a problem with your charging system. If not, then these are just crappy batteries from Costco.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 08-06-2022, 01:47 PM #3
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo is on a distinguished road
Buckaroo's Avatar
I also think it likely you are overcharging....issue likely alternator/voltage regulator.
2002 & 2017 XLE Camry
2004 Honda Accord
2005 T4R Limited V6
2010 Mazda MX-5 Touring
2017 Tundra Limited DC 5.7L TRD 4WD
Buckaroo is offline   Reply With QuoteReply With Quote
Old 08-06-2022, 02:22 PM #4
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
It took me three tries to get a good battery from Costco (pre-covid, when I was driving more often).
I used to buy my Interstate batteries from an Interstate battery store, and never had a problem.
2004 Limited V8 4WD 182k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 07:17 PM #5
Took a few days before I could get by HF to pick up a cheap digital voltmeter.
Battery (engine not running): 12.85
Battery w Alternator (engine running, A/C on): 13.78
I cleaned to the top of the battery and will monitor, but I'm going to chock it up as possibly another bad battery from Costco.
On a possibly related note, my passenger side valve cover gasket is seeping onto the alternator itself, likely shortening it's potential lifespan (and possibly causing the original issue, but I'm not sure how). Will swap the gasket and clean up the alternator when I do plugs in the next 30 days and continue to monitor.
Thanks y'all
battery , issues , months , normal , noticed
Strange Battery Issue SaxAndLiz 3rd gen T4Rs 5 05-21-2020 08:27 PM
Sunroof issue-Believe battery the cause. Breadman03 5th gen T4Rs 2 05-15-2017 03:25 PM
Battery Light issue? SweetWaterSurprise 3rd gen T4Rs 9 07-14-2013 11:07 PM
Battery or starter issue? NathanOfSeattle 3rd gen T4Rs 10 12-09-2012 09:46 PM
Battery Issue/Question?? mac777daddy 4th Gen T4Rs 14 01-26-2012 01:40 PM
