Old 08-06-2022, 03:17 PM #1
Dominic Dominic is offline
Dominic is on a distinguished road
Transmission Noise
Hi all, I'm getting some noise (sounds like a whine) under acceleration and changes when decelerating. While at speed, shifting to neutral eliminates the deceleration whine noise...
I changed the fluid sometime ago and looks nice and red still when I checked it. Level appears to be fine. I did have to replace the driveshaft (old one starting to seize up and had no zerks) with a new toyota one and greased it after installation. Rotating the driveshaft by hand and everything feels tight, no looseness. Shifts are still firm and crisp, no gear slip or anything...
Specs are 2005 V8 RWD, any ideas?
Dominic is offline   Reply With QuoteReply With Quote
Old 08-07-2022, 04:26 PM #2
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
Rear differential. Ever changed the fluid or checked the level? If you get it up on jack stands (firmly supported), have someone run the trans in drive while you are underneath (very carefully not getting tangled up in anything moving) and listen to the diff with a mechanics stethoscope, you might be able to tell where it is coming from. Classic diff issue, noise changes when you are accelerating under load vs coasting.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 08-26-2022, 09:43 PM #3
Sorry for late response, I got a video of it. Changed the diff fluid, level was fine and fluid looked clean.
August 25, 2022 - YouTube
2005 4runner
2004 corvette
Old 08-26-2022, 11:49 PM #4
stevelikesrhino stevelikesrhino is offline
stevelikesrhino is on a distinguished road
Doesn't quite sound like transmission (don't quote me on that). The sound doesn't shift, like you can't hear transmission shifting gear. Probably want to check driveshaft installation? IIRC you need to line up the shaft otherwise it's not balanced.
stevelikesrhino is offline   Reply With QuoteReply With Quote
driveshaft , noise , toyota , whine , zerks
Transmission noise 549alex 3rd gen T4Rs 15 08-16-2021 09:56 PM
Transmission Noise? Dous 3rd gen T4Rs 3 03-18-2012 09:53 PM
Transmission Noise jtschmitz Classic T4Rs 2 05-01-2010 04:47 PM
transmission noise? Supremeng 4th Gen T4Rs 0 08-01-2008 10:55 PM
transmission noise - was noise in reverse jmfranc 3rd gen T4Rs 2 07-07-2008 08:10 AM
