Old 08-06-2022, 03:27 PM #1
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
Anyone replace ABS Control Module/Brake Booster??
long time issue here. took 4runner (2007 230k v6 4wd one owner) to the dealer in March. after $300 in diagnostics, they determined my issue is with the ABS control module back feeding into the system.
PLEASE REFERENCE THREAD: Brake lights constantly on?
afterwards, i examined the plastic encased module and noticed impact backs in the case. very weird. did it let in moisture for years and damage the computer boards?? no idea what happened.
since, been trying to figure if there is an alternative answer. even at discount, a new module is about $800 (P/N 47217-35010), new Master cylinder with booster is $1200 (P/N 47025-35070). add labor to that.
backstory: the original master /abs module was replaced any about 111k miles because of constant squealing. put in a used unit that had about 70k miles on it. things were fine until the past year or so (based on people telling me my brake lights are constantly on).
so, after several months, i'm am considering biting the bullet and replacing the unit again. now, i'm wondering how common this issue is. i think economically the best bet is to go with a used unit that includes the master cylinder ($1200 part), and having it independently installed. maybe three hours labor charge. probably in over $500. it is a crapshoot. i'm having to go on the dealer's conclusion. could be wrong.
does anyone have experience with these units, and their installation?
rwh963 is offline   Reply With QuoteReply With Quote
Old 08-06-2022, 04:42 PM #2
and, has anyone just replaced the module? according to the dealer, that is the failing part. i would even consider a new one if i could do the replacement myself. not sure of tools/procedure.
Old 08-06-2022, 05:01 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I'm wondering if when you did the replacement if the one you got was from a different year 4th Gens, I know the part number is different on the early year models to the later year models, if it wasn't from the same year as your T4R that could explain why it makes the brake lights stay lit up because of maybe different circuitry in the module.
When replacing this time make sure you get the proper part number and make sure the replacement has that same part number
2004 Limited V8
Old 08-06-2022, 10:41 PM #4
thx for the suggestion. i believe it was the correct PN.
Old 08-07-2022, 07:34 AM #5
Jim_A Jim_A is offline
Jim_A is on a distinguished road
Might be an option. 2005 - 2007 Complete Toyota 4Runner ABS Unit 89541-35050 - Wholesale Parts Express
Jim_A is offline   Reply With QuoteReply With Quote
Old 08-07-2022, 09:27 AM #6
Originally Posted by Jim_A View Post
thx for looking into it. i can actually get a new (not refurbished) unit like that for sub $1200. however, i only need the black plastic control module. replacing the whole unit is more complicated and i would outsource that (Labor $$). however, just the electronic unit might be a DIY effort, or at least a small $ labor cost. haven't found a "professional" level video demonstration of what that entails.
Old 08-07-2022, 12:27 PM #7
here are a couple of pics of what i discovered after the dealer diagnostic in march. i took a closer look at the module unit then, to discover serious impact cracks on the module housing! it was never noticed before. i don't know if the dealer did it, or the installer at 111k miles, or was it sold to me damaged and not noticed since. no clues. at this point, i need to replace the module.
Anyone replace ABS Control Module/Brake Booster??-thumbnail-jpg
Old 08-07-2022, 12:28 PM #8
another:
Anyone replace ABS Control Module/Brake Booster??-thumbnail-jpeg
Old 08-07-2022, 12:29 PM #9
one more:
Old 08-07-2022, 05:34 PM #10
some pics of a module on ebay. maybe this will help someone explain how this mounts.
Anyone replace ABS Control Module/Brake Booster??-s-l1600-jpg
Old 08-07-2022, 05:35 PM #11
backside:
Old 08-07-2022, 05:36 PM #12
backside 2:
Old 08-07-2022, 07:38 PM #13
Real Name: Skip
Real Name: Skip
With it having oil rings on the mounting plate, it would have brake fluid going into it, so at the very least it's going to take a special service tool to help bleed the air out of it once installed I would think.
As long as the master cylinder isn't messed with most anyone can bleed the brakes after messing with brake lines, calipers, etc., but with the modern ABS brakes system, once you open up the master cylinder in any way it's going to take a special service tool/scanner to open and close the ABS valves to release any trapped air when trying to bleed the master cylinder.
2004 Limited V8
Old 08-07-2022, 08:15 PM #14
in the end, it might be better to score a used complete unit here or on ebay or salvage yard. expect +/-$400. then probably another $2-300 for install. i've had good luck with the dealer price matching independent labor, might better to have the dealer do the install.
Old 08-08-2022, 01:03 AM #15
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
You still f_cking with this sh1t!! What happened last time, you thought you had this figured out right? I'll have to read the old thread I can't remember all the details. 👽
Jakeepoo3 is offline   Reply With QuoteReply With Quote
issue , labor , master , module , unit
Hard Brake Pedal During Panic Stops - Brake Booster? Friday88 3rd gen T4Rs 24 04-24-2024 12:14 AM
Very dangerous braking behavior after electronic brake booster module replacement Charles Bronson 5th gen T4Rs 19 04-13-2022 04:17 PM
2001 4runner electric brake booster/pump with abs module zwalker16 For Sale: T4R Items 0 08-27-2021 08:48 PM
anyone ever mess up a brake booster by changing brake pads? jluu6r 3rd gen T4Rs 19 12-12-2019 05:01 PM
2001 abs module/booster leaking 01thunder 3rd gen T4Rs 9 01-28-2019 12:01 AM
