Old 08-06-2022, 06:32 PM #1
2003V8LTD 2003V8LTD is offline
2003V8LTD is on a distinguished road
Wierd new oil leak -- anyone recognize?
Guys, I was under the car today (2009 V6 4wd Limited) and I noticed a new oil leak. There are two big cast arms that extend from the front diff and are bolted through the main front crossmember. The left side one looks like always but the right side one was covered with oil (these pics are after I wiped it somewhat off). It's thick, black oil, not motor oil or ATF.
A couple weeks ago I had the dealer change pretty much all the fluids in the car, including the oil in the diffs and transfer case. Any idea what this new leak could be? I'm thinking that a seal or something on the front diff must have failed.
Thanks for any heads-ups!
4r1
4r2
4r3
2003V8LTD is offline   Reply With QuoteReply With Quote
Old 08-07-2022, 08:34 AM #2
Derekv Derekv is offline
Derekv is on a distinguished road
That side gets a little oil on my 2004 Sport V8 when I remove the oil filter.
Could be your front diff. Maybe clean it really well, drive a bit and see if you can tell where it is coming from.
Derek V
Derekv is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 08:24 AM #3
Derek V
I think I have narrowed it down to the front diff/ third member assembly. The seal on the LHS of the third member where the halfshaft bolts up to it must be perished. I don't think it is from a normal motor oil spill because the oil is thick and black, not thin and golden-brown. Sounds like a major pain in the rear to replace it!!
Old 08-08-2022, 09:01 AM #4
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
Looks like the diff seal. Have you checked the fluid level?
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 04:13 PM #5
MikeinNH67's Avatar
MikeinNH67 is a jewel in the rough MikeinNH67 is a jewel in the rough MikeinNH67 is a jewel in the rough
MikeinNH67's Avatar
If it's from the diff it will smell like stinky gear oil. Like mentioned check the level first.
My first thought was whoever changed the motor oil last did not do a good job catching it but that may be a different setup than on the V6.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 08-10-2022, 09:35 PM #6
Yup it's just a V6 (2009) and I think you might be exactly right. It's pretty much directly below the oil filter and perhaps when someone unscrewed it they spilled some oil. (I wouldn't ordinarily have noticed it except that I took the skid plates off to respray them.)
Old 08-11-2022, 10:22 AM #7
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of
Bluesky 07's Avatar
They definitely spilled some if they didn't put something under the drain tube that comes off the bottom of the V6 oil filter mount.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 08-17-2022, 06:48 PM #8
MikeinNH67's Avatar
MikeinNH67's Avatar
By your name I assumed you have a V8. :-)
Mike
03 4runner Limited
Old 08-19-2022, 04:36 AM #9
stevelikesrhino stevelikesrhino is offline
stevelikesrhino is on a distinguished road
Free undercoating
stevelikesrhino is offline   Reply With QuoteReply With Quote
Old 08-20-2022, 01:57 PM #10
inscarguy's Avatar
inscarguy inscarguy is online now
Real Name: brian
inscarguy will become famous soon enough inscarguy will become famous soon enough
inscarguy's Avatar
Real Name: brian
Self lubricating chassis.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Nitto grappler g2 275 55 20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, General Grabber ATX 275 55 20, Magnaflow Exhaust,, Powerstop brakes, sport hood.
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back exhaust, 4Runner XP rims, Michelin Defender LTX 275/55-20,sport hood.
inscarguy is online now   Reply With QuoteReply With Quote
Old 08-22-2022, 08:50 AM #11
We have a 2003 V8 and a 2009 V6, both silver Limiteds. I love the V8 but boy does it ever swill down gas ...
diff , front , leak , oil , side
Does anyone recognize this '91? GrubRunner89 New Members 3 04-03-2021 10:29 PM
Anyone recognize this? FLY_FISHING 5th gen T4Rs 14 08-03-2020 06:58 AM
Anyone recognize this 3rd Gen? ghostmoney 3rd gen T4Rs 12 01-10-2017 12:17 PM
Recognize this '07 T4R? Land Shark 1971 General Discussions 0 11-17-2014 04:10 PM
