Old 08-15-2022, 06:12 AM #16
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold
Real Name: Brett
If the ECU has not reported any DTC (check engine light) associated with a bad CC, I would be hesitant to spend that kind of money on something that may or may not be the problem. The fact that you only experience the smell occasionally is something I could live with if the vehicle is otherwise running good. It's obviously running efficiently considering your reported mpg.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 08-17-2022, 04:53 PM #17
MikeinNH67's Avatar
MikeinNH67 is a jewel in the rough MikeinNH67 is a jewel in the rough MikeinNH67 is a jewel in the rough
MikeinNH67's Avatar
For OEM parts that price is not terrible. In the rustbelt getting those manifolds off can be a bear. Kicker is if an upstream cat is actually physically degrading then the debris will end up in the downstream cat which is not listed. Assuming the engine runs good and if no odd noises I would certainly hold off on the cats. Like mentioned, when you smell it do check the temps of the wheels and do a sniff test on them. I've had a bad axle seal allow gear oil to drip on the brakes which is an odd smell but very specific to the corner with the issue.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
build , catalytic , converter , exhaust , part
catalytic converter hulk311 3rd gen T4Rs 6 11-24-2020 05:12 AM
catalytic converter grousehunter 61 Classic T4Rs 8 01-24-2018 02:21 PM
Catalytic converter MLo 5th gen T4Rs 1 01-16-2014 02:05 PM
catalytic converter Milesy894runner Classic T4Rs 1 12-28-2010 12:42 AM
