Old 08-13-2022, 08:01 PM #1
Bolderboulder's Avatar
Bolderboulder Bolderboulder is offline
Bolderboulder is on a distinguished road
Removing Engine Cover - Bolt stripped/slipping
The driver's side bolt securing the engine cover is either stripped or slipping. It turns but will not back out. I tried applying upward pressure to that side of the engine cover while loosening the nut, but that did not work. I sprayed some Liquid Wrench on it but that did not help.
Aside from carefully cutting the cover's plastic as close around that nut as possible to remove the cover, does anyone here have suggestions?
I would greatly appreciate it!
Removing Engine Cover - Bolt stripped/slipping-20220813_092454-001-jpg
Bolderboulder is offline   Reply With QuoteReply With Quote
Old 08-14-2022, 09:52 AM #2
Bigshankhank Bigshankhank is offline
Real Name: Tyler
Bigshankhank is on a distinguished road
Real Name: Tyler
Gotta think you could score a replacement engine cover from a junkyard fairly easily, so cutting out around that bolt probably wouldn't be too earth-shattering.
Something else you could try is getting a 1/8" cobalt-tipped drill but and drilling around the edge of the nut until it breaks apart. Time consuming though.
2008 4Runner SR5 V6 4WD
Bigshankhank is offline   Reply With QuoteReply With Quote
Old 08-14-2022, 10:18 AM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Drill or grind the head of the bolt off and then drill out the remaining part of the bolt, then retap the hole if it's not stripped, if it is stripped then drill it a bit bigger and retap the next size up.
2004 Limited V8
Old 08-14-2022, 11:51 AM #4
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I think what's happening is the stud that the nut screws on to has broken loose from the bracket and the stud is turning. See if you can reach under the cover with a pair of needle nose and grasp the stud and then turn the nut.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 08-14-2022, 12:33 PM #5
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Yup this.
Its basically a bolt glued to a rubber spacer and another bolt glued to the other side.
They come unbonded.
The cover may just pull up.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 08-17-2022, 08:30 PM #6
Originally Posted by BackOff View Post
Yup this.
They come unbonded.
Thanks everyone! I used a small, curved blade chisel to score the plastic surrounding the bolt, then gently pulled upward on the cover and that stuck bolt slid through the scored plastic.
The culprit was that bolt's metal sleeve in the cover. Someone had tried to pull the cover off without removing the bolt and that metal sleeve became dislodged in the cover.
The cover came off, I degreased the top area of the engine and the engine cover, cleaned the cover with denatured alcohol, applied a coat of "The Black Stuff," and then a coat of ceramic coating. I also cleaned the Mass Air Flow sensor.
bolt , cover , engine , nut , side
Removing stripped seat bolt MrEMan 3rd gen T4Rs 16 05-21-2023 12:27 PM
Stripped Engine Cover Stud - 2006 4.0L ahs46 4th Gen T4Rs 4 04-06-2018 03:39 PM
Need help removing broken valve cover bolt AnotherCO4Runner 3rd gen T4Rs 31 12-08-2017 12:34 AM
Top hat bolt stripped help! Chubbs22 3rd gen T4Rs 3 09-30-2014 02:41 PM
Broken engine cover bolt. what to do wolf4runner 4th Gen T4Rs 2 10-24-2012 04:20 PM
