Originally Posted by BackOff
Yup this.
Its basically a bolt glued to a rubber spacer and another bolt glued to the other side.
They come unbonded.
The cover may just pull up.
Thanks everyone! I used a small, curved blade chisel to score the plastic surrounding the bolt, then gently pulled upward on the cover and that stuck bolt slid through the scored plastic.
The culprit was that bolt's metal sleeve in the cover. Someone had tried to pull the cover off without removing the bolt and that metal sleeve became dislodged in the cover.
The cover came off, I degreased the top area of the engine and the engine cover, cleaned the cover with denatured alcohol, applied a coat of "The Black Stuff," and then a coat of ceramic coating. I also cleaned the Mass Air Flow sensor.
