Old 08-18-2022, 05:44 PM #16
gookies gookies is offline
gookies is on a distinguished road
Originally Posted by alia176 View Post
Forgive my questions as I didn't digest all of the replies below but would it more of a PnP (plug n play) by purchasing pre-made hard lines from the dealer online? I use Claremont Toyota for a substantially reduced price and free shipping. See if it's worth your time before going the custom DIY route.
it's been a while since I removed the fuel tank but do the fuel tank strap bolts screw into captive nuts on the chassis? Of course, one would need to soak these hardware in PB Blaster or similar and pray that the bolts will come lose. Is there space above the captive nuts to introduce hardware store nuts should the captive nuts don't want to release the hold on the bolts? Again, apologies for not remembering if there are any wiggle room in that area.
I've had couple of instances where the captive nuts were corroded and I removed them then replaced them with regular nuts. But, I had the room to make this happen, which isn't always the case.
How to knock out captive nuts - simply use a hammer and a dull punch to knock them out. They have tiny amount of welds so they're easily knocked out of their perches.
HTH.
Bending lines isn't too difficult with NiCopp lines and it's significantly cheaper, so I don't mind bending it myself.
Yes, they do bolt into some welded nuts inside the frame as I've read on the sticky about replacing them. And there may be some space to possibly get a nut in or as I posted above, a user ended up using rivnuts. I'm definitely soaking it in PB plaster for several days before trying to remove it.
gookies is offline   Reply With QuoteReply With Quote
Old 08-19-2022, 10:45 AM #17
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Rivnuts are a great option if space is too tight for a regular hex nut. I've used them for adding a second fuel tank on my Landcruiser. Please use actual Rivnuts and not nutserts.
I used the tool below for my 3/8" x 16 Rivnuts and here's the link below: C722 / C845
Rivet Nut Tool | Rivnut(R) Installation Tool | Rivnut(R) Tool | Rivnut Hand Install Tool | Rivet Nut Installation Tools
Pic below
I wouldn't use these types of nutserts because they may not heavy duty enough but I've used on other applications.
Amazon.com: AKKTOL Rivet Nut Tool Heavy Duty 16”, Rivnut Tool Nutsert Tool Kit with 15PCS Metric/SAE Mandrels 125 PCS Rivet Nuts and Carrying Case for Entry Level and Professional Use : Automotive
Advice - Replacing Brake Lines-rivnuts-jpg
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 with whole bunch of stuff!
alia176 is offline   Reply With QuoteReply With Quote
leaking , lines , replace , shop , tank
Replacing Brake Lines gookies 4th Gen T4Rs 19 06-09-2022 11:18 AM
Replacing rust belt brake lines front end 2000 SR5 4Runner Gary Blake 3rd gen T4Rs 33 02-23-2022 10:04 AM
Replacing all brake lines (92 4Runner) Awdtsi42o Classic T4Rs 4 03-24-2017 02:13 PM
Advice/opinions on SS Braided brake lines DMX512 4th Gen T4Rs 0 03-11-2017 07:29 PM
Need help with replacing brake lines Adumb 4th Gen T4Rs 2 09-01-2015 07:51 PM
