Old 09-06-2022, 11:09 PM #31
othompson824 othompson824 is offline
Real Name: Owen
othompson824 is on a distinguished road
Real Name: Owen
Originally Posted by Bogrun View Post
So there's the stage 2si and the magnum. I really just didn't think I'd notice the difference between them and didn't want to spend the extra cash when I was already getting a 100%+ increase in flow from the stage 2si. That extra money went towards the y-pipe
I got the plug and play MAF chip. Install takes 5 minutes if that. I'm still testing my mpg (just finishing the first tank with it now, won't know for sure until 2-3) but I suspect I'm getting slightly better efficiency now just based on how long this tank has lasted me. Definitely not any worse. Also slightly difficult to gauge because I've been having a lot of fun putting my foot down and hearing the new exhaust scream!
Ok sweet. Oh so you like recently installed all this! Well lmk how it goes, and hey i dont blame you flooring it all the time, your car must sound awesome!
othompson824 is offline   Reply With QuoteReply With Quote
Old 09-06-2022, 11:16 PM #32
Real Name: Owen
Real Name: Owen
Originally Posted by techno View Post
My Walker exhaust system rusted out and literally fell off the vehicle, so I replaced it with the AFE Y-Pipe (which deletes the two downstream cats) and the Magnaflow Overlander cat back system. Very noticeable improvement in power over what I had. It holds gears longer before downshifting on inclines and acceleration is way better. Yes, the Magnaflow is LOUD even with the mildest setup, but the performance gain I got makes it worth continuing with. The only intake mod I have is the HCF delete.
Sent from my moto g stylus 5G using Tapatalk
Im liking the idea of a Y-pipe, they seem to help a lot. But I live in California, do you know if it would pass emissions or not?
Old 09-07-2022, 05:48 PM #33
Real Name: Owen
Real Name: Owen
And do y-pipes affect clearance at all? I may be better off just going with the magnaflow overland exhaust on its own.
Old 09-07-2022, 06:08 PM #34
Bogrun's Avatar
Bogrun Bogrun is offline
Bogrun will become famous soon enough
Bogrun's Avatar
I'm not familiar with California's laws but I know they're among the strictest in the country so I'd so some research before making the commitment. There aren't any inspections in Michigan so unfortunately I couldn't even give you my best guess if it would pass.
I can say there are no check engine lights with it as it only removes the rear catalytic converters so as far as the 4Runner is concerned, no issues there. And if you're curious, I got about $75 for the two rear cats.
The URD y-pipe doesn't affect clearance any. It does reroute the y-pipe to go under the transmission pan but it still fits under my RCI skid plates just fine. I also haven't noticed an increase in my transmission temperature since installing the y-pipe as measured with my scanguage.
I installed my exhaust and y-pipe at the same time so I can't say for certain what portion to the overall sound it's responsible for but it's very deep and throaty. It sounds more like a truck than any off-the-lot V8 you'd get from the big 3. Definitely not a wasp nest!
Bogrun is offline   Reply With QuoteReply With Quote
Old 09-07-2022, 07:55 PM #35
T4r.Chris's Avatar
T4r.Chris T4r.Chris is offline
T4r.Chris is on a distinguished road
T4r.Chris's Avatar
Not sure if it’s been mentioned yet, but a simple drop in K&N filter definitely felt like it did something on the butt dyno. I have a “race pedal” throttle control (similar to a pedal commander) which just helped day to day driving and getting up to speed. Magnaflow dropped their Overlander exhaust system a while back for a lot of Toyota’s. Not sure of the power difference if any on that.
2005 4Runner SR5 - Build Thread- https://www.toyota-4runner.org/4th-g...ld-thread.html
T4r.Chris is offline   Reply With QuoteReply With Quote
Old 09-08-2022, 03:42 PM #36
Bleu62 Bleu62 is offline
Real Name: Clay
Bleu62 is on a distinguished road
Real Name: Clay
I was very disappointed with the pedal commander, what is the MAF chip? I’m guessing it’s changing the air fuel ratio rather than pedal input? How does it work and is it better than the pedal commander if you have tried that?
Bleu62 is offline   Reply With QuoteReply With Quote
Old 09-08-2022, 10:43 PM #37
Real Name: Owen
Real Name: Owen
I have not, but I believe it reprograms the ECU to lean out the mixture, depending on if you have any mods or not, and what those mods are. I think they make a pretty significant improvement even on stock trucks. Pedal commander, however, doesn't affect performance at all and instead just changes the sensitivity of the pedal and makes it more or less responsive.
Old 09-09-2022, 08:30 AM #38
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
Originally Posted by daprotege5 View Post
Did you cut your old cats and weld them on or bought new aftermarket??
Have pictures of your setup by chance??
Sorry for the late reply, had to resize to be able to upload
Best performance mods for 4th gen V6?-20180802_181016-jpg  Best performance mods for 4th gen V6?-20180802_181315-jpg
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 04:23 PM #39
Real Name: Owen
Real Name: Owen
Any updates?
Old 09-25-2022, 09:00 AM #40
Bogrun's Avatar
Bogrun's Avatar
Any updates?
Finishing the last tank of gas I had before the intake, exhaust, and tune was about 17.5mpg and the after the first tank of gas with them I was reading 18.6mpg.
Unfortunately I had to reset my computer last night removing my battery to install my new suspension so I won't be able to track how it increases from there but I'll be watching it closely again.
I noticed you really feel the power gains at higher speeds above 60mph or in the higher RPMs. If you just want to feel a big difference in your day-to-day driving around town I'd say the Sprint Booster is almost more noticeable if you're just trying to make the 4Runner feel more sporty and quick on it's feet.
It's also worth noting I'm riding on oversized all-terrains so your mileage may vary. I'll update again after I get some more miles after my lift
cais , mods , performance , start , tube
Best Performance Mods JayKumar 4th Gen T4Rs 48 08-18-2022 05:47 PM
5th Gen Performance Mods 1engineer 5th gen T4Rs 72 12-09-2020 04:18 PM
Performance Mods for the v6? UberGoober 5th gen T4Rs 36 09-03-2014 08:30 PM
06 SR5 Performance Mods TacMedic New Members 0 02-17-2011 12:07 AM
performance mods??? jrh607 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 04-22-2005 07:17 AM
