Old 08-19-2022, 09:50 AM #1
Rsbhunter Rsbhunter is offline
Rsbhunter is on a distinguished road
Wire tracing for battery light
Posted before, 2006 4.0 sport, Batt light on after new Batt and 2 rebuilt alt. Wires have not been chewed, messed with, etc. If there is power on both sides of the fuse in the dash fuse block, would that not mean the problem was between there and the dash panel, or am I just being hopeful ? I am starting to think about pulling the fuse block in the engine bay, but if the problem is farther towards the dash, why bother? What is the physical path that the grey "batt" light wire takes after leaving the alt plug? Thanks for any input, I'm about ready to fix it with electrical tape, OVER THE LIGHT !! rsbhunter
Rsbhunter is offline   Reply With QuoteReply With Quote
Old 08-20-2022, 09:54 AM #2
Sat bump
Old 08-20-2022, 12:49 PM #3
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
Originally Posted by Rsbhunter View Post
Posted before, 2006 4.0 sport, Batt light on after new Batt and 2 rebuilt alt. ... What is the physical path that the grey "batt" light wire takes after leaving the alt plug? Thanks for any input, I'm about ready to fix it with electrical tape, OVER THE LIGHT !! rsbhunter
@Rsbhunter I can't say physically where that Grey wire routes but looking at the Wiring Schematic... I see a White, Grey, and a Yellow/Red wire leaving that port on the alternator. The Grey wire goes to a connector labeled EA1/EA2 (depending on which Engine you have). The other side of that connector continues as a Grey wire to IC4 ("Instrument Panel Wire and Engine Room Main Wire (Left Kick Panel)"), then to a Junction connector J18(A) From there it splits with one Grey wire going to the body ECU port 14. The other Grey wire leaving J18(A) goes to another Junction Connector labeled J8(A) and leaves that to go to port 16 of the "Combination Meter" C8(A). From there it exits as a "R-L" wire (Red / Lavender?) to a 7.5 amp fuse, that turns into a Black-Red wire to the Ignition Switch.
Adding some additional information on locations of the junctions mentioned above:
Starting from the alternator the EA1/EA2 connector appears to just be a "Connector Joining Wire Harness" the location is listed as "(Under the Engine room R/B)". pg 44/45 shows this under the fuse box near the engine.
The IC4 connector is listed as being located "Instrument Panel Wire and Engine Room Main Wire (Left Kick Panel)". Page 46 shows it 2nd one down, left side in a cluster of 5 connectors near the bottom of the dash behind the drivers door side kick panel.
Junction connector J18(A) appears to be tucked up behind the Instrument cluster Looking at Page 38 the lots of pointers here so hard to tell exactly where in the cluster.
Body ECU port 14 is under the dash looks like between the steering column and above the brake pedal.
The other Grey wire leaving J18(A) goes to another Junction Connector labeled J8(A)/J9(B) which is also tucked up behind the Instrument cluster Looking at Page 38
The "Combination Meter" port 16 C8(A) is not far from J8(A) still behind the cluster but a bit down and towards the drivers door. per Page 37.
From there it exits as a "R-L" wire (Red / Lavender?) to junction block connector 1G which appears to be an inline 4 wire plug going into the Engine room relay box to a 7.5 amp fuse and out via connector 1D as the Black-Red wire to the Ignition Switch IG2 6 That goes through the switch to port "7 AM2" which is a Red Wire going to a 30 amp AM2 fuse or fusible link then on to the battery and Ground.
I hope this description helps you. I tried to upload a copy of the pages but can't seem to add them here.
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Last edited by Boort; 08-26-2022 at 11:55 AM. Reason: Adding additional location info
Boort is offline   Reply With QuoteReply With Quote
Old 08-20-2022, 06:07 PM #4
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Have you checked the grounds? There is one from the battery to the inner fender. There may be others to check. Also back in the day there was a fusible link at the starter. I'm not sure if the 4Runners have them but if one of those melted it would cause a no start or cause a charging problem.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 02-10-2025, 10:52 PM #5
drallan drallan is offline
drallan is on a distinguished road
I know this is an old thread. Did you ever find what was causing the light? Having a similar problem.
Checked, cleaned, replaced everything I can think of and can't get the darn light to go out. About the only thing I haven't done is the starter grounds. I have a v8 and not looking forward to taking apart the top end. Especially with no issues starting. It's just the light!
drallan is offline   Reply With QuoteReply With Quote
alt , batt , dash , fuse , light
P0710- tracing a bad wire or connector? YFZsandrider 3rd gen T4Rs 10 04-20-2017 08:15 PM
Battery questions. What size wire for battery? 2 gauge enough? e60ral 5th gen T4Rs 9 03-12-2017 12:29 PM
What size wire for dual battery set up? jmt2404 3rd gen T4Rs 17 11-29-2011 03:16 PM
+12 battery wire carlscaffidi Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-18-2006 08:37 PM
How are you running your amp wire from the battery? wsudu 4th Gen T4Rs 3 04-29-2005 11:10 AM
