Old 08-01-2023, 11:51 AM #76
Piggity Piggity is offline
Piggity will become famous soon enough
Originally Posted by Napalm View Post
Over the last month, I’ve noticed a small fluid leak on the ground under the engine. This only develops after sitting for 24+ hours. It’s very minute, maybe a drop or two here and there. Crawled under her today to investigate and found the fluid on these two parts.
This part of the transmission
This bracket on this hose line
Fluid is brown and almost like oil. Engine oil seems fine on check. Any ideas ?
I'd trace the leak up in the engine bay. It could just be a valve cover leak but the first pic seems like a rear main seal. Dig around to see during the daytime when you have some light to see properly.
And great thread, I've just read the entire thing!
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 08-01-2023, 10:04 PM #77
Napalm's Avatar
Napalm Napalm is offline
Real Name: Nathan
Napalm will become famous soon enough Napalm will become famous soon enough
Napalm's Avatar
Real Name: Nathan
Originally Posted by Cezar View Post
That frame is insane. Almost concourse levels of clean.
Also 4runner gas caps are a wear item unfortunately.
Thank you! I’m pretty proud of it. I can’t take the credit though, I bought it this way. That was a product of my carelessness!
Thank you! I’ve enjoyed documenting it!!
That’s a good idea. I started from the bottom, but maybe a top down approach will help. I’m hoping it’s not that rear main seal, not sure how expensive those run! Thanks for the input though!
2007 SR5 V8
2017 Limited
Napalm is offline   Reply With QuoteReply With Quote
Old 08-14-2023, 03:56 PM #78
Napalm's Avatar
Real Name: Nathan
Napalm's Avatar
Real Name: Nathan
Detail day!
Still have been unable to locate leak. But I’ve been checking fluids regularly and everything seems to still be normal.
2007 SR5 V8
2017 Limited
Old 09-07-2023, 06:01 PM #79
Napalm's Avatar
Real Name: Nathan
Napalm's Avatar
Real Name: Nathan
My coolest mod yet!
Been considering doing the timing belt/water pump job before my son comes in a few weeks. Just hitting 200k, my runner is overdue for it. I’ve looked into it - and it looks beyond my mechanical skills.
Anyone paid a shop to do this job - about how much should I expect?
2007 SR5 V8
2017 Limited
Old 09-07-2023, 06:30 PM #80
JustRidin JustRidin is offline
JustRidin is on a distinguished road
I've heard quite a wide range of price quotes, but recently in Denver I've gotten quotes around $1200-$1500 inclusive of replacing the water pump and pulley tensioner.
I'd definitely shop around a few shops in your area and really drill down on what all they replace. It's one of those jobs that you have to disassemble so much, you might as well replace all the cheaper parts you can to avoid repeat labor in the future. Also, work warranty will be important as well.
JustRidin is offline   Reply With QuoteReply With Quote
Old 09-08-2023, 12:13 PM #81
Napalm's Avatar
Real Name: Nathan
Napalm's Avatar
Real Name: Nathan
Thanks for the info! That’s about what I was expecting.
I’ve read this as well - one forum post stated to go ahead and change spark plugs. Any other recommendations that you know of for replacement during this same job - I mean if they are gonna be in there, might as well do it.
2007 SR5 V8
2017 Limited
Old 09-25-2023, 12:42 PM #82
Napalm's Avatar
Real Name: Nathan
Napalm's Avatar
Real Name: Nathan
Got a quote from my local dealership for $1100 for the timing belt + water pump job, that’s the best one I’ve gotten so far actually. Looks like she will be headed in soon for that!
Fair weather cruise photo from the other night!
2007 SR5 V8
2017 Limited
Old 09-28-2023, 11:11 AM #83
Napalm's Avatar
Real Name: Nathan
Napalm's Avatar
Real Name: Nathan
Dropped off the old silver fox for Timing belt, water pump, and transmission drain and fill. I also asked him to replace the pulley tensioner if they had any in stock!
Loved seeing the other V8 4th gen pull in behind me, so cool to see two 15+ year runners still on the road running strong.
My dealer was nice enough to comp me a rental for the day or so it’ll take them for the timing belt job, pretty nice ‘23 Camry Nightshade
I’ve got to say - I love what Toyota is doing with these newer Camrys. The bronze wheels are just awesome!
2007 SR5 V8
2017 Limited
Old 09-29-2023, 10:50 AM #84
Napalm's Avatar
Real Name: Nathan
Napalm's Avatar
Real Name: Nathan
Picked up! Fresh timing belt, water pump, and had them drain and fill the transmission.
Best part - all Toyota brand parts and came with a parts/labor warranty for 12months/12k miles.
2007 SR5 V8
2017 Limited
Old 10-03-2023, 12:17 PM #85
Napalm's Avatar
Real Name: Nathan
Napalm's Avatar
Real Name: Nathan
Nice morning out for a cruise and some supplies!
In the shop today for an oil and air filter change!
2007 SR5 V8
2017 Limited
Old 10-07-2023, 02:24 PM #86
Napalm's Avatar
Real Name: Nathan
Napalm's Avatar
Real Name: Nathan
Washed up!
2007 SR5 V8
2017 Limited
Old 10-07-2023, 08:25 PM #87
jsherm74 jsherm74 is offline
jsherm74 is on a distinguished road
Thank you for your service. Nice rigs
jsherm74 is offline   Reply With QuoteReply With Quote
Old 10-10-2023, 06:34 AM #88
MrWeatherman's Avatar
MrWeatherman MrWeatherman is offline
MrWeatherman is on a distinguished road
Just did the timing, water pump and both exhaust manifolds with cat. I paid a couple thousand for parts and labor so those prices given are decent for the amount of labor needs to be done.
MrWeatherman is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 09:38 AM #89
Napalm's Avatar
Real Name: Nathan
Napalm's Avatar
Real Name: Nathan
A pretty cool sight. A third gen Hilux Surf, parked next to my 4th gen here in Texas!
2007 SR5 V8
2017 Limited
Old 12-02-2023, 06:27 PM #90
4thGenCanuck 4thGenCanuck is offline
4thGenCanuck is on a distinguished road
Very nice!
4thGenCanuck is offline   Reply With QuoteReply With Quote
4runner , build , texas , thread , vehicle
Tigger's Build and Mis-Adventures tigger 5th gen T4Rs 140 05-07-2022 09:55 PM
Adventures of 4RnR Grl (and build) 4RnR Grl 5th gen T4Rs 451 06-27-2021 11:57 PM
Tbrock's Build & Adventures TBrock 5th gen T4Rs 63 10-30-2017 01:18 PM
HODOR's build and Adventures lipek 5th gen T4Rs 227 08-20-2017 08:58 PM
The Build & Adventures of Valken Dane2992 5th gen T4Rs 0 04-20-2016 01:51 AM
