Old 08-23-2022, 09:15 AM #1
flaco21 flaco21 is offline
flaco21 is on a distinguished road
05 4RN Rear Upper Control Arms
I have an 05 sport where one of the brackets holding the rear upper control arm snapped off. I cannot get anyone to form one and weld it back on top of rear axle. I cut the arm off as it was just hanging. The other one is good. Are these really needed or can It be driven with just one arm? Is the solution for this issue is to get a rear axle assembly? Wondering if anyone has experienced the same issue.
flaco21 is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 02:31 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I THINK you could drive it with one arm for a while, BUT I would keep trying to find someone to weld on another bracket. You might have to drive an hour or two to find someone, but I would definitely get it replaced.
If worse came to worse, you could remove the axle assembly and take it to someone who may be comfortable doing it off vehicle.
Call your dealer and ask them to refer you to someone. What would they do if they had such a problem?
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 08-23-2022, 03:51 PM #3
MikeinNH67's Avatar
MikeinNH67's Avatar
Do you mean the 2 foot-ish tube on both sides that bolts to the axle then forward to the frame? If so I would not drive it except to maybe get it home if nearby. The axle will twist and is not safe like that.
How and where did it fail? The bracket rust off the frame? If so, you can have these types of things below welded on but more frame issues will be coming.
Mid Frame Section w/ Trailing Arm Mount (ART-202-L) Driver Side - autorust.com
Pics are helpful.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
arm , axle , issue , rear , upper
Upper rear control arms all the same? St Runner 3rd gen T4Rs 2 01-11-2021 10:25 AM
MetalTech Rear Upper Control arms Taylor20 3rd gen T4Rs 2 06-18-2018 09:40 PM
Upper rear control arms dylan_n_00 5th gen T4Rs 4 07-17-2017 01:20 AM
WTB: 3rd gen upper/lower control arms/rear trailing arms BADCLOWN Want to Buy/Trade 2 05-24-2017 03:11 PM
Adjustable Rear Upper Control Arms 97 _SR5 3rd gen T4Rs 15 09-11-2014 03:40 PM
