Old 08-23-2022, 09:29 AM #1
Bolderboulder's Avatar
Bolderboulder Bolderboulder is offline
Bolderboulder is on a distinguished road
Fix to use LED fog lights instead of halogen?
My LED fogs stopped working so I replaced them with 9006 halogens and those work fine.
I assume the lower amperage of the LEDs is the issue. Is there a simple dix to use the LEDs?
I also read here that halogens should be used in fog lights because of their lumen advantage over LEDs. Is that true?
Bolderboulder is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 01:34 PM #2
OopsIBrokeIt OopsIBrokeIt is offline
OopsIBrokeIt will become famous soon enough
Or are the bulbs simply dead? Maybe plug one into the headlight connector and see if it turns on.
LED bulb quality is all over the place, and without knowing what you were running it could simply have had some component die internally.
OopsIBrokeIt is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 02:12 PM #3
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
In any light designed for use with halogen bulbs, you should generally stick with halogens. Most of the aftermarket drop-in LED bulbs - when slapped into housings designed for halogens - are a downgrade in performance. (No matter what the marketing hype says.)
Now, if you change over your whole housing with something designed from the ground up as an LED light, that's a totally different story. I swapped out the OEM LED fogs in my 2021 T4R for Diode Dynamics SS3 Max fogs and the difference is truly staggering.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 02:45 PM #4
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
I second this. Where did you get your Led foglight bulbs?
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 05:03 PM #5
I bought the fog LEDs, and all of the other LEDs that I converted from halogen, from Amazon.
I didn't think to plug the fog LED into the headlight socket to check function, duh! That's why I'm not a professional mechanic!
If the fog LEDs are indeed bad, it's too late to return them. I believe they were about $30 for the pair.
Thanks for all of your assistance!
Old 08-23-2022, 05:22 PM #6
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
check your polarity on the plugs, the stock plugs are reverse polarity, you can get lucky if you aftermarket bulbs lets you flip it around.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 08-24-2022, 08:34 AM #7
You might find this to be an interesting read:
Why LEDs should not be run in Halogen reflectors | Tacoma World
Old 08-24-2022, 08:41 AM #8
Great information, thank you!
fog , halogens , led , leds , lights
Max Amount of 55W Halogen Lights? MrSeth 4th Gen T4Rs 2 11-29-2019 03:59 PM
IPF 968 Halogen Lights $120 Nor Cal TheeMikeB For Sale: Non-T4R Items 3 06-15-2014 11:15 PM
Surco 4560 with 4 halogen lights for sale RunnerJeff 4th Gen T4Rs 1 08-21-2013 10:18 PM
Silverstar zXe Halogen Lights NWSKIUrbanRunner 4th Gen T4Rs 15 11-17-2011 01:18 AM
HID Halogen lights johnpsmith84 Classifieds - buy & sell (no commercial ads please) 1 01-28-2009 04:04 AM
