Old 08-26-2022, 02:36 PM #16
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Originally Posted by rwh963 View Post
if made by Denso, can it be purchased without the Toyota mark up? and, is this a DIY job? i saw a tube video the showed an access port under the rear driver side carpet that allows you to unplug the pump electronically. in this video, they also cut the thin floor sheet metal to lift the pump out without dropping the tank (i am not recommending that method!).
Yes, I linked to it on Amazon (~$109) in my post above as did Dr. Coffee (since RockAuto charges shipping, it's essentially a wash). But be aware that you'll need to remove the old pump from the housing and install the new one as shown in the illustration.
Also note the two-stage fuel filter system; the one called "fuel filter" is in the housing (pic in my previous post) and then there's the one which comes with the fuel filter and kind of resembles a coffee filter. So if you want a new fuel filter too, you'll need the housing, which is Toyota p/n# 2330050120. I paid ~$ 38 at a dealer's online parts store.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 08-26-2022, 04:03 PM #17
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
so, is there also a fuel line filter, or is the pump filter the only one? i'll have to look upon the part referenced, but does it include the sub tank? and replace the sender as well while in there?
rwh963 is offline   Reply With QuoteReply With Quote
Old 08-26-2022, 07:33 PM #18
Bluesky 07's Avatar
Bluesky 07's Avatar
The only fuel filters are the two in the tank, the one in the housing and the one on the bottom of the fuel filter. I would definitely replace the sender given the difficulty of getting to it and the seeming inevitably of eventual failure. OEM is ~$100; can't remember if aftermarket is available for less. The sub tank is not included and there is no reason I'm aware of to replace it. I didn't.
Old 08-26-2022, 08:28 PM #19
looks like i can get the whole shebang for $320 from the dealer (2003-2009 Toyota 4Runner - Fuel Pump - Toyota (23221-31050). good value? probably more than piecing it together, but one stop shopping and guaranteed.
Old 11-07-2022, 03:17 PM #20
dgwood12's Avatar
dgwood12 dgwood12 is offline
Real Name: Dustin
dgwood12 is on a distinguished road
dgwood12's Avatar
Real Name: Dustin
I know your post is a few months old so I am not sure what you decided to do but I am also looking to replace my fuel pump. After some research, I believe the part number and price you listed (23221-31050 for $320) is just for the Denso pump and not the entire fuel pump housing, sending unit, filter, etc. Did you order this part and if you did, can you confirm what you received?
I found part number 7702035112 which appears to be everything included for $643.80.
I am still debating on what to do but I am thinking $643 for the entire unit is way too much. I am thinking I may just replace the pump and sending unit. I thought about also doing the filter while I'm at it but there's some more info on the filter in this thread that's making me think it might be unnecessary:
Servicable Fuel Filter?
Either way, its still < $300 if I source the pump with strainer (Denso from Rock Auto), Fuel Sending Unit, Fuel Filter and a new Tank Gasket (all OEM from my local Toyota dealer).
2008 4Runner SR5 4x4 (Galactic Grey Mica)
Got Satoshi? - Compiled: Satoshi Build, Help & Picture Thread
dgwood12 is offline   Reply With QuoteReply With Quote
Old 11-07-2022, 11:54 PM #21
thanks for the question. as not turns out, i did not have to replace anything. earlier, i had thoroughly cleaned the throttle body. i DID NOT DO ANY RESET AFTER THAT. apparently, there is a recommended procedure to do reset the computer. i just kept driving it. took a good while for the symptoms to disappear. btw, been running strong and smooth since.
so, you may not need to replace anything either. do the throttle body cleaning first.
Old 11-08-2022, 12:41 AM #22
othompson824 othompson824 is offline
Real Name: Owen
othompson824 is on a distinguished road
Real Name: Owen
Originally Posted by UrbanRunner651 View Post
My 08 has 209k on it and mine is starting to show signs of failure.
What are signs of failure?
othompson824 is offline   Reply With QuoteReply With Quote
Old 11-29-2022, 05:53 PM #23
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Do you have any advice for taking the assembly apart to put in the new filters, fuel pump, and level sending unit?
I've seen a lot of videos and writeups for how to get to the fuel pump assembly, but not much about how to take it apart after that. I don't see anything about it in the FSM either.
djpope09 is offline   Reply With QuoteReply With Quote
Old 11-29-2022, 06:24 PM #24
Bluesky 07's Avatar
Bluesky 07's Avatar
I don't. I took mine to a shop and they did the assembly.
Old 12-10-2023, 03:50 PM #25
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
i need this info as well.. dropped the assy, but the pump is encased in plastic housing, can see how to disassemble it
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 02-12-2024, 10:23 AM #26
ans77030 ans77030 is offline
ans77030 is on a distinguished road
How to rebuild the fuel pump tank assembly - anybody done that?
I had a hesitation under load issue with my 2004 V6 that I initially thought was due to fuel starvation (fortunately it was due to a wonky MAF). Getting ahead of myself, I pulled a fuel pump assembly out of a donor vehicle with the intent of rebuilding it and replacing the electric pump with OEM Denso at the very least. I have taken the fuel pump assembly apart to see where the fuel pump lives and wonder how to remove the OLD electric original fuel pump. It appears to just be a friction fit at first glance, but doesn't want to come out. Am I not seeing a lock fitting or fastener or does it need to be gently hammered out? Would appreciate advice on replacing the original electric pump and top filter housing from anyone that did this before. Thanks!
ans77030 is offline   Reply With QuoteReply With Quote
190k , clock , fuel , pump , stock
Replace Fuel Pump - Drop Fuel Tank? Rock_Rat 3rd gen T4Rs 11 12-17-2023 05:33 PM
Fuel Pump Relocation? or Fuel Pump Hatch? Cygnus 3rd gen T4Rs 3 01-24-2022 03:06 PM
No Fuel? Bad Fuel Pump? Bad Fuel? Aliens? Gremlins? 007Tacoma 5th gen T4Rs 12 05-04-2018 09:08 AM
Repeated fuel filter clog, failing fuel pump, or ? hour 3rd gen T4Rs 74 10-09-2016 12:58 PM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
