Old 01-03-2016, 07:16 PM #1
pearlj10 pearlj10 is offline
pearlj10 is on a distinguished road
Wiring diagram help
Happy 2016. I'm finally getting ready to install 2006 XSP power seats into my 03 SR5. I've got the power wiring and all other seat wires for the 03 (seat belt, airbag, occupant sensor, etc.) all figured out. What I don't have a handle on is which wires I need to connect the 03 wires to on the XSP seat connectors (I don't have pigtails for the 06 connectors). I've reviewed the 06 FSM stickied on page 1 of this post and cannot find wiring diagrams. I found all of the seat wiring diagrams for the power components on the 06, just not all of the other wiring (seat belt, airbag, occupant sensor, etc.). Am I missing that info in the 06 FSM? Or can someone please post the wiring diagrams for those particular items? I would be much obliged.
I will be creating a post on the install when I am done, as I have had a hell of a time finding the right info to do this swap.
Thanks!
pearlj10 is offline   Reply With QuoteReply With Quote
Old 01-05-2016, 12:29 AM #2
Anyone? Please?
Old 01-05-2016, 01:32 AM #3
ADeFazio's Avatar
ADeFazio ADeFazio is offline
ADeFazio is on a distinguished road
ADeFazio's Avatar
Can you post pics of the factory harnesses and the plugs on your new seat?
ADeFazio is offline   Reply With QuoteReply With Quote
Old 01-05-2016, 01:49 AM #4
ADeFazio's Avatar
ADeFazio's Avatar
Not the greatest quality but might help:
Wiring diagram help-image-gif
Old 01-05-2016, 02:00 AM #5
morganashley0524 morganashley0524 is offline
morganashley0524 is on a distinguished road
Helppppppp!!!! Pleasee!!!!
Does anyone know how to install this? I have a 2005 toyota 4runner and I was hoping to install it in the center console in the blanks
Wiring diagram help-screen-shot-2016-01-05-12-32-00-am-jpg
morganashley0524 is offline   Reply With QuoteReply With Quote
Old 01-05-2016, 02:08 AM #6
morphious's Avatar
morphious morphious is offline
Real Name: John
morphious is on a distinguished road
morphious's Avatar
Real Name: John
@pearlj10 2 Things that are brought to my mind which could be completely wrong but 1) I thought XSP was a port option so not sure if seats are standard wired though I think they are just covers over stock seats but not sure 2) I don't think 03-05 SR5 or Sports have the body wiring harness for power seats, I believe only Limiteds came with the 2 front to back body wiring harnesses that have the ability to plug in power seats. These are the 2 things I thought about, but could be off base, good luck.
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
morphious is offline   Reply With QuoteReply With Quote
Old 01-05-2016, 02:10 AM #7
ADeFazio's Avatar
ADeFazio's Avatar
whoa thread jack. That thing is incredibly easy to install. Search.
The following two diagrams include seatbelt harnesses and passenger seat occupancy sensor wiring:
Wiring diagram help-06_4runner_seatbelt_harness-gif  Wiring diagram help-06_4runner_pass_seat_occupancy-gif
Old 01-05-2016, 02:18 AM #8
How do I get it into the radio for the audio
Old 01-05-2016, 02:26 AM #9
ADeFazio's Avatar
ADeFazio's Avatar
you don't. You will also need to add a USB interface GROM Audio TOYNU2P Android and iPhone Compatable USB Interface
Old 01-05-2016, 10:44 PM #10
Thanks for the diagrams ADeFazio. I had skipped over the diagrams for the seat occupancy sensor and buckles. Those are from the 03 FSM, I'm guessing? Here's a photo of the main connection on the XSP SEAT. I'm thinking that I only need to supply power to the two light green wires at top right, and ground to the narrow white/black wire at bottom left, according to the diagrams.
Wiring diagram help-image-jpg
Old 01-05-2016, 10:46 PM #11
Another shot of the main harness on driver's XSP seat. The two green wires at right are the ones that need power, which is included with my 03 SR5 harness. The ground wiring, I believe, is the narrow white and black wire at left.
Old 01-05-2016, 10:50 PM #12
This is the other main connector on the XSP seat. The gray and white wires go to the air bag/seat position sensor and I know which two wires from my SR5 harness I need to connect to those. The black and the black with white stripe wire on the XSP connector are for the seat belt buckle sensor, I have no idea which two wires from my SR5 harness need to connect to these.
Old 01-05-2016, 10:53 PM #13
This is the main passenger connector on the XSP seat. I know I need to run power from the 30 amp fuse in drivers kick panel to the light green wire on XSP harness, and a ground to the narrow white with black strip wire.
Old 01-05-2016, 10:59 PM #14
Other than running power and ground to the main passenger XSP harness, I am totally lost on how to wire this seat. The green, red, and yellow wires at connector at left in this image go to the lumbar support. This connector looks like it might connect to the connector with the black, yellow, and green wires at right but they certainly do not connect. I'm not even sure what the connector at right with the black, yellow, and green wires is used for. Nor do I have any clue what I need to connect to these two connectors to make the seat work. I would guess that only a power and ground would be needed for the lumbar switch, but why there are three wires in the connector escapes me. Perhaps the connector at right with black, yellow, and green wires is for the passenger seat belt buckle sensor? Again, these XSP seats are from an 06. Any help at all is GREATLY appreciated.
Thanks
Old 01-05-2016, 11:11 PM #15
I almost forget t this connector on the passenger XSP seat. This one is my guess for the seat belt buckle sensor. Again, no idea what to hook up to this.
97 4Runner ECU/ECM wiring diagram/PIN diagram Dawgz 3rd gen T4Rs 5 02-20-2023 03:04 PM
Wiring Diagram theking11863 Classic T4Rs 5 08-07-2015 08:21 PM
wiring diagram Lucky4R Classic T4Rs 0 08-03-2015 10:31 PM
Anyone got the diagram for connector G18 (electric wiring diagram) jicko 5th gen T4Rs 0 04-03-2015 10:01 PM
Wiring Diagram? bmwm3owner General Discussions 0 08-13-2008 02:24 PM
