Old 08-27-2022, 08:10 PM #1
werminghausen werminghausen is offline
werminghausen is on a distinguished road
2003 4R 4.7l overheated fatally?
I changed the timing belt after 200k miles (3rd belt) and I have forgotten to fasten one cooling hose properly
What happened, the hose from the thermostat to the radiator popped off and I lost 2.5 gallons of fluid (from total 3.2 gallon total) and the engine overheated dramatically... I did not realize this cruising on the highway.
I heard unusual mechanical engine noises and then I saw the temperature gauge in the red zone,. also the CEL was on.
I stopped and shut the engine off. I was very uncertain if I already damaged something.
After shut engine down I saw that the one coolant hose came off and I lost most of the fluid.
On the highway I did not get the typical smoke/vapor as a sign for overheating... only when I slowed down the car.
Also I did not get a low fluid lever dash light. I saw after the fact that the check engine light came on and also
I waited for the engine to cool down and meanwhile I got some water... I connected the hose back to the thermostat housing and filled 2 1/2gallons of water (what I lost) back to the cooling system. In the beginning there was still a lot of vapor coming out.
The car started normally and I could drive home. The engine seemed to work normally. (As i had no tools to connect the hose properly I left the cap open, so no pressure could build up)
The engine ran about 100miles meanwhile and I cannot see any difference or strange behavior. Am I just lucky and nothing bad happened....or it there some aftermath with this incidence?
Questions:
-Might the engine have some damage after severe overheating?
-What can be the consequence in that event of severe overheating.
After the incident I am questioning.
Why did I not get a proper warning for low coolant level or serious overheating?
Does Toyota not have these basic warning lights.
As I said I did get the high temperature reading but no acoustical or warning signal or low fluid level.
Best, Martin
werminghausen is offline   Reply With QuoteReply With Quote
Old 08-27-2022, 08:22 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all
rdruss's Avatar
Real Name: Ron
I would do an oil change and see if any metal of any kind comes out and I would carefully cut open the filter and check the filter pleats for metal. If you see no signs of metal then you need to keep close watch on oil consumption.
You may not have scuffed pistons to cylinder wall but may have scuffed the ring faces to cylinder wall. Either situation will show up as excessive oil consumption and it could start a little while from now, so keep watch if and make sure you don't run low on oil.
If you do see metal, then you know the engine is damaged. Obviously, it is still drive able, but there is damage and depending on how much to a piston(s), one could come apart and cause catastrophic failure.
If you have access to a borescope, you could pull the plugs and inspect each cylinder that way for scuffing. You would see verticle smear marks on the cylinder walls.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 08-28-2022, 12:26 AM #3
djkurious djkurious is offline
djkurious is on a distinguished road
Our gauges are very slow to respond. Same happened to me in 2017 but no damage.
2003 4Runner SR5 V8
319k and counting...
djkurious is offline   Reply With QuoteReply With Quote
Old 08-28-2022, 11:15 AM #4
Thanks, I just did the oil change before the overheating happened (I did the new timing belt and oil change).
I'll watch and monitor closely the oil consumption from here on.
By the way... Does anyone know if the T4R 2003 4..7 has a low oil warning light
or a low coolant light?
Old 08-29-2022, 09:52 AM #5
aemravan aemravan is offline
aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future
If it cooled off and fired up and has ran for the past 100 miles the likely hood of some major damage is not high. Only thing I could think of is a possibly warped head which could cause exhaust gas in the coolant system. You'll know it's happening if you start seeing pressure built up in the coolant system causing it to push excess fluid out through your overflow tank.
With that said though.. it could be perfectly fine, or it could have resulted in some pre-mature wear, it's hard to tell without an inspection. My suggestion... if your oil looks like and isn't milky (I don't see you ending up with metal shaving in your oil from an overheat.. if it was to that point you would likely see a seized engine by now) and you're not pushing excess fluid from your overflow tank just forget it happened and be more cautious next time. But I can definitely see how missing the fact that the one gauge on your cluster that typically doesnt move once hot creeped into the red without you noticing.. I don't know of any low coolant level sensors that I"ve ever seen on this (or other cars ive had) but yea it would be nice to have an audible alarm once you peg the red zone on the temp gauge.
2003 Limited V8 4runner - Tacoma Front End Swap - Icon 2.5 front coilovers - Dobinsons IMS59-50575 LT Shocks w/ C59-749V springs - Coastal Off-Road Bumpers - ARB Front/Rear Lockers - 4.56 Gears - RCV front axles - Twin-stick FJ T-case swap - LC200 Steering Rack Swap
aemravan is offline   Reply With QuoteReply With Quote
Old 08-29-2022, 06:05 PM #6
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
When you first turn the ignition on before you turn it to start, all the lights you have in the instrument cluster will light up, look and see what there, I know there isn't a "Low Coolant" light, but I would think there is a "Low Oil level" light but I don't know for sure without looking.
Also look in your owner's manual, it shows all the lights in the instrument cluster, and gauges etc.
2004 Limited V8
Old 08-29-2022, 07:21 PM #7
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Low oil pressure most common, oil level, not so.
Old 08-29-2022, 08:12 PM #8
Thanks everyone for their comments and answers.
I'll keep monitoring the engine oil level and the coolant level.
I have not seen any sign of coolant level nor engine oil level dropping.
Also I checked the engine oil today. From what I can tell the color is the same as the new oil I put in.
I'll keep fingers crossed but I am still cautious.
One question about the coolant type.
After I lost all of the red coolant the only coolant I could get quickly was the Presone (label claims: for all vehicles). I know that different manufacturers have their own coolant although I don't know or understand the background (for me the engines are not very different from materials....)
What are your thoughts... Can I drive with the yellow Prestone or would you recommend to change back to the Toyota coolant?
Thanks, Martin
I'll check on my dash what lights there are. However I think I have not seen oil pressure, low oil level or low coolant level.*
*I am mostly driving my old Mercedes Benz cars from the 70s to early 90s. They all have oil pressure, low oil level and low coolant level.
Old 08-30-2022, 06:05 AM #9
Real Name: Skip
Real Name: Skip
Thanks, Martin
I would most definitely change the coolant for one that is rated for Asian vehicles, especially Japan made vehicles, the other coolants have additives that can cause corrosion in Toyota systems, it doesn't have to be the Toyota brand as long as it rated for Asian/Japan vehicles.
2004 Limited V8
Old 08-31-2022, 11:50 AM #10
Thanks, that is what I will do: Change the coolant to the Toyota stuff (red or pink)
In order to drain entirely are there block drains for the left and right side block?
Old 09-28-2022, 04:58 AM #11
ckisling ckisling is offline
ckisling is on a distinguished road
Overheat
I have a 2004 v8 with 190,000 on it. I had similar situation with overheating except I was on the phone taking driving 80 mph when I noticed some stream coming out. By that time then looked down and noticed check engine light came on and then could hear ticking going on, then the engine then died and I coasted to side of the road. Had it towed to a shop close by and we put coolant in and it wouldn’t start. They did coolant test I think enzyme or something and it was fine. Then compression test and cylinder 3,4,7 and 8 all failed. They said engine is shot and I need a new one and quoted my around $10k. Do I need to do any more tests from another mechanic or is it safe to assume the heads are completely shot cracked or block cracked? There is no oil or coolant leaking anywhere on the vehicle. It fires up but of course dies with that many misfires. They gave me options to rebuild it at just under $10k and a new rebuilt engine at $11k with warranty. Any ideas, I’m at a lose what to do and I’m not dumping $10-11k into an engine?
ckisling is offline   Reply With QuoteReply With Quote
Old 09-28-2022, 08:39 AM #12
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
on the phone talking, didn't notice engine overheating. horrible timing.
rwh963 is offline   Reply With QuoteReply With Quote
Old 09-28-2022, 08:46 AM #13
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
How mechanically skilled are you and how much time do you have? Have vehicle towed to your place and start your own investigation until you are satisfied one way or other that engine is junk or not. Then decide what you are going to do. If it's junk you are going to spend some bucks, or walk away.
Old 09-28-2022, 09:51 AM #14
I’m mechanically inclined and have done done extensive stuff to this 4runner and my daughters that is the same year just the v6. I just don’t know what other tests to do or take it to another local mechanic? The mechanics it’s at now seem like they are price gouging and not wanting to see if it can be done without full engine replacement. Plus the car is 45 miles from me and they know that.
Old 09-28-2022, 10:09 AM #15
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Assume the worst, that you need an engine and do your own research on a replacement; used, rebuilt, and see what you come up with. Determine what you are willing to spend to put your 4Runner back on the road and if it makes sense to have it towed home or someplace else.
engine , fluid , hose , lost , overheating
Overheated cdrewferd 3rd gen T4Rs 11 02-06-2014 12:00 PM
Stuck in mud...overheated A/T DEKA3 5th gen T4Rs 37 05-30-2013 08:02 PM
Any way to tell if an engine has overheated? lcchik 3rd gen T4Rs 6 07-29-2012 10:24 PM
Overheated (please help) superduty Classic T4Rs 2 09-21-2010 12:37 AM
Just got 1992 T4R and got overheated... 4R_in_Uzb Problems & Warranty Issues 1 07-04-2007 01:44 AM
