Old 08-29-2022, 08:10 PM #1
084runner480 084runner480 is offline
084runner480 is on a distinguished road
Rear Main Seal???
Surely there's a write up for replacing the rear main seal right?
Have searched, can't find it.
084runner480 is offline   Reply With QuoteReply With Quote
Old 08-30-2022, 07:57 AM #2
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
I would assume you would have to pull the motor or drop the trans.
There is some info for 3rd gens but didn't see much else. Probably means it's not a common issue on 4th gens
Are you leaking or what's the reason for replacement?
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 08-30-2022, 08:47 AM #3
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
main seal is located between the engine and the transmission. on the v6, you have to remove i believe it was 6 bolts and the plate covering the seal, once you replace the seal, make sure to also seal the cover plate as it requires the toyota sealant when you go to close it up.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 08-30-2022, 06:34 PM #4
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Try AT205 reseal. Stuff works great
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 09-01-2022, 12:26 AM #5
P_nlsn's Avatar
P_nlsn P_nlsn is offline
Real Name: Parker
P_nlsn has a spectacular aura about P_nlsn has a spectacular aura about
P_nlsn's Avatar
Real Name: Parker
I replaced my rear main seal whenever I swapped my engine. There's not a ton to write up, but I attached the 1GR-FE FSM page, as well as a picture of it, below. And feel free to pm or reply with any questions. You either have to drop the trans or pull the engine to access it. You take the flywheel off, pull the old seal, press the new one in, and put it all back.
You have to make sure you seat it pretty close to perfect because it would really suck to go through the trouble of replacing it, just to have leak again. I would honestly only recommend tackling the job if it is leaking really bad or you are already pulling the engine for other reasons because it's hard to get to.
Here is a picture of my old engine's leaky seal (with multiple years of dirt, mud, and grease build-up)
4wd V6 '03 Sport w/ 340k miles (175k engine swapped @ 326k) // 3" Suspension Lift + 3" Body Lift on 35" K02's
@toto.runner // Build Thread // Engine Swap Write-Up
P_nlsn is offline   Reply With QuoteReply With Quote
Old 09-01-2022, 07:37 AM #6
make sure to put the flywheel back on the right way as well. wasn't fun having to pull the motor cause i put it backwards
Old 09-01-2022, 08:23 AM #7
Drcoffee's Avatar
Drcoffee's Avatar
Before you do this consider that the crankshaft may have a groove at the seal and even a new seal will still leak. I have talked to many mechanics over the years and its a real possibility on high mileage engines.
find , main , rear , seal , searched
Rear Main Seal K2Runner 3rd gen T4Rs 24 05-03-2022 12:15 PM
Doing Rear Main Seal - Anything else while in there? franky73 3rd gen T4Rs 4 09-20-2018 09:50 PM
Rear main seal HELP superdavebigD 3rd gen T4Rs 1 03-14-2018 09:21 PM
Rear Main Seal Yotaguy_95 Classic T4Rs 3 05-02-2013 03:08 PM
Rear Main Seal Steve8v92 Classic T4Rs 0 04-27-2009 09:19 PM
