Auseeker
Thank you for my only reply!
At the dealer I had them get me the tech, he assured me he used the teacstream solenoid actuated process and there is definitely no air in the system.
I also tried your recommendation a few times already to no avail. :/
I do have a question, that day we did the "big brake job" and sucked in that air. I replaced the calipers for 5th gen's (2010's to be exact) They were supposed to help with the constantly freezing caliper issue we all face.
I just read this interesting post about brakes and master cylinder/caliper piston sizes. Essentially he was saying the bigger the caliper piston the more spongy/less firm and vs versa. I wonder should I go back to the smaller 4th gen caliper??
I also did new brake hoses that day. Raybestos BH382878 Professional Grade Hydraulic Brake Hose to be exact. They look really nice, hood quality. I wonder should I go to stainless steel?
Oe. Pads are ceramic, maybe a semi metallic will bite better?
The fronts seem to barely working compared to the rears, unless I double pump. I wonder if the systems is sending out the same pressure to all 4 calipers, the rears are smaller bore and the front are bigger rhat the bore size difference is yielding a miss match in applied pressure resulting in a car that basically is only using the rears.
Am I crazy?
Best,
Tone
