Old 09-07-2022, 07:58 PM #16
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Similar thing happened to me on a Jeep I owned except no studs broke. I did the same, noticed something odd so stopped and looked around not thinking to look at the lug nuts. Two miles down the road I turned onto another road from a stop and the last nut fell off leaving the rotor sitting on the rim. Jacked it up and grabbed a nut off the other wheels, I may have found one too. Since then whenever I have a wheel off I will check the lugs again after a test drive. Multiple times I've found a short drive shows that the lugs were not seated or something as they needed to be tightened. Permanent regimen now.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 09-08-2022, 12:07 PM #17
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
I would just like to add that this style of lug/wheel setup is the easiest of all to cause problems if you're not very careful. These nuts with the shank can easily cause the wheel to bind up if you don't tighten them sequentially in a star type pattern. I teach my students to tighten all 6 nuts very slightly while watching to ensure the wheel is pulling back flush then go back over them for a final tightening again using a star pattern. When I do it myself I also lightly grease the shank portion of the lug nuts. The regular bevel style nuts are much more forgiving but IMO they aren't nearly as strong.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 09-02-2024, 08:51 PM #18
KD5NRH KD5NRH is offline
KD5NRH is on a distinguished road
Originally Posted by mrblah View Post
So it can happen to OEM manufactures too, if you don't follow the specs.
Had it happen on several different vehicles back before I started loosening and re-torquing my lug nuts any time someone else put a wheel on, unless I personally watched them use a torque wrench on them *and* saw it turn before clicking. (Does no good if they've already rattled them to 150 then throw the wrench on just to make sure it's enough.)
That was probably 20 years ago, and I haven't had one of any brand strip or snap since. That's including a few I've put the cheapest studs that would fit in after buying the vehicle with a stripped or missing stud.
KD5NRH is offline   Reply With QuoteReply With Quote
bearing , lug , nuts , studs , wheel
Wheel Studs hdhp65 4th Gen T4Rs 4 12-27-2019 08:20 PM
Wheel studs 4runnerfevr 3rd gen T4Rs 3 11-19-2018 11:45 AM
Lug nut and wheel studs help! 4RunnerKyle 3rd gen T4Rs 3 01-21-2015 06:32 PM
Need help with Wheel Studs Castaway 3rd gen T4Rs 9 06-16-2013 01:03 PM
Wheel studs... awinter78 3rd gen T4Rs 8 08-14-2011 01:29 AM
