Old 09-05-2022, 12:17 PM #1
AZ4's Avatar
AZ4 AZ4 is offline
AZ4 is on a distinguished road
AZ4 AZ4 is offline
AZ4's Avatar
Angry When four of six wheel studs fail simultaneously and your tire falls off
TLDR: sudden catastrophic failure of wheel studs on Detroit Axle aftermarket wheel bearing assembly. Tire fell off while pulling out of a parking space. Why? The fact that two studs didn't break off and I couldn't find the lug nuts for them suggests those two were loose and fell off. Did I over or under torque the nuts the last time I worked on the car?
Story: I had a loud, intermittent clunk on my 2007 Toyota 4Runner (4WD). I replaced a ton of things chasing the noise, including the wheel bearings. I used 2pc Detroit Axle set from Amazon ($160). Problem was solved.
Two months and two thousand miles later, I was driving down the road at 40 mph and noticed a slight thumping sound coming from the passenger's side. I thought it was a mudflap. Pulled over, parked, and did a visual inspection. Turned the steering to full lock on each side and looked at the suspension. I couldn't see anything amiss... but I did not look at the lug nuts.
As I was pulling out of the parking space, the goddamn passenger's side wheel came off and the car landed on the rotor. The tire lodged itself between the ground and the wheel well. Thank ****ing god I wasn't on the highway or off-roading.
I jacked it up to assess the situation and relieve the tire from it's predicament. Saw that four wheel studs snapped off the bearing. I found two lug nuts next to the car with the studs still inside. I could not find the other four lug nuts.
I was 200 miles from home. Quotes for a tow were $1200-$1600. I felt ****ed. Lots of people gawked, some and offered to help. I refused them all, not knowing what they could do. It was starting to get dark. I was panicking and felt helpless.
I called a buddy of mine for a consult. He offered to drive up with a new wheel bearing and tools to help me fix it. He is awesome.
But I calmed down and realized there was an AutoZone a mile away. I finally accepted the help of a stranger and got a ride. I bought a wheel bearing assembly, 200pc tool set, breaker bar, axle nut socket, LED work light, stole a lug nut from each of the other tires, and got to work. Less than two hours later, I was driving away. Success!!!!
I'm replacing the other wheel bearing today. I do not trust Detroit Axle.
When four of six wheel studs fail simultaneously and your tire falls off-img_2499-3-jpg  When four of six wheel studs fail simultaneously and your tire falls off-img_2514-3-jpg
2007 SR5, 6Cyl, 4WD - Sonoran Steel Lift, Pioneer AVH-X5700BHS Head Unit, HCF Delete
AZ4 is offline   Reply With QuoteReply With Quote
Old 09-05-2022, 01:14 PM #2
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Well, that truly sucks. Glad you were able to repair it and make it home. There is a reason Detroit Axle stuff is so inexpensive.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 09-05-2022, 01:53 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
This experience highlights the reason why many repairs involving removing wheels suggests re-checking the lug nut torque a few days/miles afterward. Not that I ever have, but I may now.
You might contact Detroit and let them know what happened, not in an accusatory tone and see if at least they would like the failed hub for their own analysis, you never know how they might respond.
Yes, glad it happened in parking lot, could have been real ugly!!
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 09-05-2022, 03:10 PM #4
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Definitely a good idea. I check my spacers every time a wheel is off for any reason and double-check the lug nuts too.
Nice job on getting yourself home, OP.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 09-05-2022, 04:32 PM #5
AZ4's Avatar
AZ4 AZ4 is offline
AZ4 AZ4 is offline
AZ4's Avatar
Thanks! My girlfriend was impressed.
Old 09-05-2022, 04:56 PM #6
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Lady luck is a great mistress to have. Glad you're ok and no serious damage was done.
Just out of curiosity what torque number are you putting on the lugs?
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 09-05-2022, 09:57 PM #7
AZ4's Avatar
AZ4 AZ4 is offline
AZ4 AZ4 is offline
AZ4's Avatar
Re: Luck. Absolutely. Thank you for your kind words.
Working on my car so much, I got into a bad habit of not using my torque wench and guesstimating with my breaker bar. Never again.
But you would think a few extra foot pounds (plus or minus) wouldn't cause such a catastrophic failure.
If that is the root cause, so be it. But, if Detroit Axle is a known bad supplier, I would like to know and spread the word.
I proactively replaced my driver's side wheel bearing this morning with the same AutoZone part installed after the incident.
And I used my torque wrench.
Old 09-05-2022, 09:59 PM #8
AZ4's Avatar
AZ4 AZ4 is offline
AZ4 AZ4 is offline
AZ4's Avatar
Someone posted this in a different forum today:
TikTok challenge has users loosening lug nuts to 'see what happens' | WSET
I have to wonder if I was a victim of this.
Old 09-05-2022, 10:13 PM #9
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
That's really messed up , do young people today really not think what could happen when they do life threatening things like this, it's one thing to endanger yourself but when you endanger others just for fun there's something gone really wrong with their thinking!!
2004 Limited V8
Old 09-05-2022, 10:31 PM #10
Real Name: Brett
Real Name: Brett
Tik tok challenge is gonna get these kids shot and innocent people in major accidents. SMDH
I would say the odds are higher that you were the victim of faulty parts, but you never know.
I actually went and upgraded my torque wrench today because of your post.
I've been using a Pittsburgh for way too long......
Also, 88 ft lbs is a number that has been good to me over the years.
Old 09-05-2022, 10:49 PM #11
AZ4's Avatar
AZ4 AZ4 is offline
AZ4 AZ4 is offline
AZ4's Avatar
What did you get?
Old 09-05-2022, 11:19 PM #12
Real Name: Brett
Real Name: Brett
What did you get?
Icon
It did pretty well in this YT test
Old 09-06-2022, 12:02 AM #13
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
a buddy of mine's wheel almost fell off, 4 out of 6 studs broke on a OEM hub assembly.... I was with him when it happened.
anybody wanna guess why?
Cuz the idiots at the tire shop used a impact gun on his wheels. Seriously, don't over torque the wheels man....
So it can happen to OEM manufactures too, if you don't follow the specs.
Old 09-06-2022, 09:47 AM #14
AZ4's Avatar
AZ4 AZ4 is offline
AZ4 AZ4 is offline
AZ4's Avatar
Old 09-07-2022, 06:53 PM #15
AZ4's Avatar
AZ4 AZ4 is offline
AZ4 AZ4 is offline
AZ4's Avatar
Update
I contacted Detroit Axle, and they made no attempt at a refund, warranty, or had any interest in inspecting the item. They told me to deal with Amazon, and the return window had already expired. Do not recommend.
bearing , lug , nuts , studs , wheel
Wheel Studs hdhp65 4th Gen T4Rs 4 12-27-2019 08:20 PM
Wheel studs 4runnerfevr 3rd gen T4Rs 3 11-19-2018 11:45 AM
Lug nut and wheel studs help! 4RunnerKyle 3rd gen T4Rs 3 01-21-2015 06:32 PM
Need help with Wheel Studs Castaway 3rd gen T4Rs 9 06-16-2013 01:03 PM
Wheel studs... awinter78 3rd gen T4Rs 8 08-14-2011 01:29 AM
