Old 09-08-2022, 08:02 PM #1
gookies gookies is offline
gookies is on a distinguished road
[Ideas] Patching/Repairing Brake Line
As you all might know, Toyota put some sort of rubber coating on the brake line, the weak point is at the ends, where it's just bare steel, I don't know why they did that (my guess is to give enough clearance to remove the fitting, but they also could've used a thinner rubber coating to solve that) but that's a very common spot where it ends up failing. I just replaced both of my rear lines and ended up melting away the rubber with a torch on the line I replaced, the brake line looks great underneath. By doing this, you'd be able to patch that small segment at the end, instead of having to replace the entire line.
The problem I have now is I don't want to take a torch to a line that has brake fluid in it since I'd be boiling it (but maybe it doesn't matter too much since I'll be flushing the lines later on and it melts pretty quickly), does anyone happen to know of any solvents that would dissolve this rubber coating? Willing to experiment.
gookies is offline   Reply With QuoteReply With Quote
Old 09-09-2022, 06:33 AM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Not sure about a solvent...but I would try scraping it off and then sanding it with some sandpaper to do the final cleaning.
2004 Limited V8
Old 09-09-2022, 07:32 AM #3
It's bonded to the steel line, I believe it's vulcanized, would not be able to physically scrape it off. Think this is very useful to know for others if they don't want to replace a difficult line, like the ones running near the gas tank (in my case). The rest of the line that's rubber coated is likely to be in great condition.
Old 09-09-2022, 01:36 PM #4
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
I would never "patch" a fuel or brake line. I have seen compression fittings fail and when they do its big. The only way a brake or fuel line should be fixed is complete replacement or cut out the bad spot, flare it and use a union between the two.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 09-09-2022, 02:11 PM #5
That's what I mean by a patch, flaring the lines, not compression fittings. The way the Toyota brake lines are is that they have a rubber coating that stops a few inches before the fitting. The line typically fails at this point, where the steel is showing. In order to flare it, you have to cut out the bad portion and then remove some of the rubber coating before this.
Old 09-09-2022, 04:32 PM #6
MikeinNH67's Avatar
MikeinNH67's Avatar
Hmm, it's not just a plastic coating you can cut off with a utility knife? It's been awhile since I did the lines on mine so I could be mixing up the coating with another car I worked on.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 09-09-2022, 05:25 PM #7
Real Name: Skip
Real Name: Skip
I still think it could be removed manually, if not by scraping then as mentioned cutting/slicing off as much as possible and then sand the rest off, no way would I try and burn it off.
I just did a web search on what solvent will dissolve rubber and here's the search results, some of them says there are many things that will dissolve rubber, but it also depends on the type of rubber, but the most common was Acetone, but I'll let you read all the rest of the results.
the solvent used to dissolve rubber - Search
2004 Limited V8
Old 09-09-2022, 06:11 PM #8
It seems like a pretty tough rubber coating, but maybe I just need to use a sharper utensil and try again.
Possibly, may give it another attempt with something sharper (just attempted with a random pocket knife I had). Yeah, I probably stumbled upon similar searches as you did, then also saw a comment stating vulcanized rubber is pretty tough and not too many solvents can dissolve it. It did not take long at all to melt though.
Old 09-09-2022, 10:41 PM #9
Attempted it again with a sharper blade and that was the problem, after I made an incision, I was able to peel it off. Line looks brand new underneath.
[Ideas] Patching/Repairing Brake Line-rn_image_picker_lib_temp_f4213880-c7a0-4320-ac9f-8c17561e2394-jpg
Old 09-10-2022, 08:12 AM #10
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Buy a 25’ coil of NiCopp brake line and replace the part you took off. It wont corrode and easy to form. That old steel line will be difficult to flare and will rust at every point you nicked the painted surface. Do it once and do it right. That coil of NiCopp is $25. 4Lifetimelines.com
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 09-10-2022, 08:21 AM #11
I did that with both of the rear lines, this line is the one running on the frame rail right near the gas tank, annoying to remove, so will likely patch/splice this one for now. I also have another headache and ended up snapping the front gas tank strap bolt while trying to replace the straps, rear one came out fine though. Nice to know the rubber coating did its job, also, I plan on using some thick shrink tubing that seems similar to this rubber coating they applied to cover the exposed steel.
Old 09-10-2022, 08:34 AM #12
Real Name: Skip
Real Name: Skip
For a better seal than shrink tubing, get some rubber dip for tool handles, probably as close as you will get to the original coating.
Make sure the connections are not leaking before sealing them.
rubber dip for tool handles - Search
2004 Limited V8
Old 09-10-2022, 09:17 AM #13
I've used plasti-dip in the past before, you'd need a few coats to have a thick layer, I did find some pretty thick shrink tubing that seems like it would work pretty well.
Wirefy 3/16" Heat Shrink Tubing - 3:1 Ratio - Adhesive Lined - Marine Grade Heat Shrink - Black - 50 Feet Roll: Amazon.com: Industrial & Scientific
Old 09-10-2022, 02:13 PM #14
Drcoffee's Avatar
Drcoffee's Avatar
You can wrap silicone tape around it. Its self sealing/adhering. Why not feed NiCopp tubing along the same path as the old line? You dont have to remove the old one, just cut off the ends for clearance. Then zip tie them together.
Sounds like you will need to drill out the old bolt. Thats never fun
XFasten Silicone Self Fusing Tape 1-Inch x 36-Foot (Red) Silicone Repair Tape: Amazon.com: Industrial & Scientific
Old 09-11-2022, 10:59 PM #15
It's a very tight spot for the ones running next to the gas tank, if you take a peek, you'll see what I'm referring to. It also clips into a bracket to prevent rubbing on the frame or gas tank, so you do need to remove the old line. I'm slowly draining out the gas tank to pour into my other vehicle to see how much clearance I'll have by dropping it a bit, if there's enough room for me to remove the old line, I'll likely end up replacing both lines and may just buy OEM lines for convenience purposes + the rubber coating did do its job as seen in my picture. Then I may just use the silicone tape to wrap the bare ends on the OEM line.
brake , ends , line , rubber , torch
Rear Center Line installation and other SS brake line info tv4184 4th Gen T4Rs 7 07-10-2023 04:33 AM
FS: Galfer USA Brake Line Assembly tool with SS Line tacticalone For Sale: Non-T4R Items 4 09-09-2015 01:27 PM
e brake line too short? landcruiser e brake? D Farms 3rd gen T4Rs 0 05-25-2015 12:19 AM
Repairing brake lines SwiftRunner Classic T4Rs 15 08-31-2011 08:42 AM
Pinched hard rear brake line. Ideas? J-money$$$ 3rd gen T4Rs 8 05-28-2011 12:05 PM
