09-09-2022, 10:35 AM
General Grabber AT/X or Toyo Open Country III
Torn between these two tires. I know they are very similar but here we are. I am also debating in getting the Toyo's in a 255/80/17 as my first set of skinnies. I'm just concerned with the handling characteristics of the skinnies.
I'm coming from 285/70/17 Duratracs. They're great tires just awful loud once they wear down a bit. Hit me with some pics and your opinions if you switched to skinnies from the 285's. Thanks!
09-09-2022, 11:11 AM
I have the tall & skinny tires on my 4th gen...I'm rocking Cooper ST MAXX and man, they are incredible! No issues at all with handling...in fact, I think you get more traction (science agrees too) than wider tires. You will effectively have less issues braking, less stress on your steering and suspension, and boast higher pressure to the ground where you need it...perhaps even a slight bump in MPG with less rotational mass...
If those are the only tires you'd consider, I suggest the Toyo AT3...they are one of the most popular tires for a reason...though, I had poor luck after 10k miles on my old toyos when rain and winter came...the Coopers have been MUCH better and retaining tread and there are NO needs for chains on ice, mud or snow...and boast 55k mile warranty...just throwing that out there...
255/80r17 Cooper ST Maxx
Anyone running 255/75r17?
Should I go 285/16 or 255/16...... help
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
09-09-2022, 01:27 PM
Real Name: brian
Real Name: brian
I have the ATX's on one of my 4runners and I like them alot. Fairly quiet, fuel mileage did not change much. Had a set of the AT2's that the ATX's replaced on my GMC Sierra. Never had to use 4x4 on it. Plus they also come with a reasonable warranty for all terrains.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
09-10-2022, 12:37 AM
Thanks! I forgot all about the Cooper's, I'll have to compare them to the Toyo's, since I am leaning towards the pizza cutters.
09-12-2022, 07:47 AM
I’m running 255/80/17 Toyo at3 and am very happy with them. A noticeable improvement vs the old at2s I were running, and surprisingly comfortable for a e-load tire.
I’m a fan of the pizza cutter look.
'08 Silver SR5 V6 4x4: OEM+
09-13-2022, 12:07 PM
I'm running 255/80 ST Maxx on my 4th gen. I like the size but I only like the ST Maxx offroad. The 255/80 size is perfect for this platform. My next set of 255/80's will be the AT3 toyos, ridge grapplers, or the 34/10.50/17 KO2's. I see you're in RR, I'm in NW ABQ if you want to check my tires out.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
09-13-2022, 02:19 PM
I am definitely going to take you up on that! I'll shoot you a PM. Thanks.
Sent from my SM-S906U using Tapatalk
09-19-2022, 03:01 PM
Here are the Cooper ST MAXX shown from this morning...I agree with the difference between the Toyo ATIIs and the latest AT3s...far better overall...The Coopers are heavy but I have zero complaints on how long, how well they perform in all conditions, and how well they look!
09-19-2022, 03:02 PM
Whoops, here are the photos...
Sent from my SM-G991U using Tapatalk
09-20-2022, 02:32 AM
Real Name: Chris
Real Name: Chris
I recently went with a newer tire, the BFG Trail Terrain, which is a bit less aggressive than the K02. However, this was actually my 3rd choice. I really wanted some Michelin AT2s but they didn't come with white lettering in my tire size, then the Yokohama Geolanders were on back order. So far I've had no traction issues with the BFGs on sand and they are relatively quiet.
Florida
Current 4R: 2009 Urban Runner 4WD
Previous 4Rs: 98 SR5 4WD, 02 Sport Edition 4WD, 06 Limited V8 AWD, 07 Sport Edition 4WD, 19 TRD Off Road Prem 4WD
