Real Name: Patrick
Real Name: Patrick
4th Gen Rear Brake Calipers/Kit
Hello,
Does anyone know if Wilwood makes brake calipers that can be used to replace the rear OEM brake calipers? I'm looking to replace the entire rear brake system including Calipers, Rotors, Pads, and extended SS brake lines because of the seized caliper(s).
I've looked at Powerstop rear brake kit but am unsure. I know Wilwood makes a good product and a front big brake kit for the 4th gen 4runner but don't list anything for the rear brakes.
Does anyone have any experience with TRQ brand brake kits?
Any info or suggestion would be greatly appreciated!!
2007 Limited V8, AWD, Pelican Storage Cases, Radflo 2.5 Kit. Metal Tech Rear Offset Lower Links. 265/65/18 BFG TKO. Redline Full Synthetic lube, ARB Deluxe Bull Bar and SLEE ARB Foglight Light Surround with Rigid D2 Fogs and ARB LED Indicator/Markers. WARN 9.5XP. Dirty Parts Dual Battery Kit w/ rocker switch & Dual AGM Batteries. Gobi Stealth Roof Rack, ladder, Sunroof Insert, and Tool Box Stealth. ARB Diff breather kit.. (2) ARB Quick connect for jumpers and rear voltage access. Projecta Dual Battery voltage monitor. AGM Voltage Booster PRO “Texas Slim”.
