Originally Posted by hdhp65
Does anyone know the thred size of the front and rear diff breathers? I searched and got the OEM part number but it does not say the thread size... 1/8 pipe? 1/4 pipe? Metric? SAE?
I will continue to search but if someone knows please share thank you!
HDHP
I had to find a special swivel 90 degree for my 2nd gen front diff breather to clear.
Metric thread are known as BSPT (British standard pipe thread) those are the tapered ones. There is also BSPP (British standard pipe PARALLEL) which is NOT what you need as those are straight thread not tapered.
The size I used is 1/8" BSPT and it worked great. Use Teflon tape when installing, wrapped in the correct direction so the tape continues to roll WITH threading instead of peeling off.
Good luck.
