Old 09-16-2022, 05:28 PM #1
Ducksrus Ducksrus is offline
Ducksrus is on a distinguished road
'03 No Heat
Have an '03 where the heat does not come on. Both lines to the heater block are hot, coolant level is fine, T-stat appears to be working properly. A/C works & responds according to the set temp & in all positions of mode control. Do have a humming sound from right side of console that was thinking maybe this is some type of actuator issue & a diverter is not opening for the heat; however, not sure.
Probably time for coolant change, but do not think that is part of the issue & heat was working last winter.
Thoughts?
Ducksrus is offline   Reply With QuoteReply With Quote
Old 09-16-2022, 06:18 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
Thoughts?
Very possible that the "Blend" door actuator is not working correctly and stuck in the AC position.
2004 Limited V8
Old 09-16-2022, 07:20 PM #3
Pulled some panels off & found a small motor on side of HVAC unit where the humming sound originates. Not sure that is the issue, but have pic/video of what is going on & will try to find a parts diagram & replace the part, I think. Not much room under there & do not see much of how the motor is mounted.
Thanks
coolant , heat , issue , sound , working
Another No Heat/Warm heat thread.. please help troubleshoot bentos1 3rd gen T4Rs 39 12-08-2022 12:23 PM
*Heat On*: Heat blows on passenger side, cold air blows on driver's side biv117 4th Gen T4Rs 3 09-30-2020 10:11 AM
No Heat TennRunner 4th Gen T4Rs 2 12-24-2019 11:59 AM
No heat diagnosis and solution, heat blend door servo actuator 4by4runr 4th Gen T4Rs 4 09-15-2019 09:10 PM
Cold heat coming out but auxiliary heat? Gremcat Classic T4Rs 4 11-19-2014 09:57 AM
