Old 09-16-2022, 05:28 PM #1
Ducksrus Ducksrus is offline
Ducksrus is on a distinguished road
'03 No Heat
Have an '03 where the heat does not come on. Both lines to the heater block are hot, coolant level is fine, T-stat appears to be working properly. A/C works & responds according to the set temp & in all positions of mode control. Do have a humming sound from right side of console that was thinking maybe this is some type of actuator issue & a diverter is not opening for the heat; however, not sure.
Probably time for coolant change, but do not think that is part of the issue & heat was working last winter.
Thoughts?
Ducksrus is offline   Reply With QuoteReply With Quote
Old 09-16-2022, 06:18 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Thoughts?
Very possible that the "Blend" door actuator is not working correctly and stuck in the AC position.
2004 Limited V8
Old 09-16-2022, 07:20 PM #3
Pulled some panels off & found a small motor on side of HVAC unit where the humming sound originates. Not sure that is the issue, but have pic/video of what is going on & will try to find a parts diagram & replace the part, I think. Not much room under there & do not see much of how the motor is mounted.
Thanks
coolant , heat , issue , sound , working
*Heat On*: Heat blows on passenger side, cold air blows on driver's side biv117 4th Gen T4Rs 4 12-21-2023 07:09 PM
Another No Heat/Warm heat thread.. please help troubleshoot bentos1 3rd gen T4Rs 39 12-08-2022 12:23 PM
No Heat TennRunner 4th Gen T4Rs 2 12-24-2019 11:59 AM
No heat diagnosis and solution, heat blend door servo actuator 4by4runr 4th Gen T4Rs 4 09-15-2019 09:10 PM
Cold heat coming out but auxiliary heat? Gremcat Classic T4Rs 4 11-19-2014 09:57 AM
