Old 09-16-2022, 08:16 PM #1
gookies gookies is offline
gookies is on a distinguished road
[Help] Broken Bolt Extraction
Wanted to do some preventive maintenance and decided to replace the gas straps after I saw the sticky, rear bolt came out fine and I was able to replace that, but unfortunately, the head broke off of the front one even after soaking it in penetrating oil for a few days. I also failed extracting it using a broken bolt extractor, part of it actually snapped off too while attempting, so another headache.
I am wondering if anyone else has been in this predicament and what their solution was (also, I do not own a welder). I did read over the sticky and I don't think I recall anyone stating they snapped the front one (rear one, yes). I currently have a ratcheting strap in place, which compared to the rusty strap that was holding it before is significantly better.
gookies is offline   Reply With QuoteReply With Quote
Old 09-16-2022, 09:37 PM #2
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
If you can remove the broken bolt extractor you may be able to use a left hand drill bit. I’ve been successful doing that once. I found a cheapie set from harbor freight. I’ve also had luck using a small flat chisel and hammer to work to a bolt backwards. Good luck bud
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 09-16-2022, 09:44 PM #3
Ah yeah, I did try a left handed drill bit (the same kit you likely purchased from HF, lol) before the extractor and also tried a chisel and hammer, but unfortunately, failed. Those options might've worked on a less crusty, lower strength bolt.
Old 09-16-2022, 09:57 PM #4
Real Name: Matt
Real Name: Matt
Damnit!!! That sucks man. Maybe ask around FB groups local to you to have someone weld a nut in there for you. I guess I’m lucky to live in the desert. No rusty crusties lol. I just have dry rotted rubber seals and parts instead lol.
Maybe you can punch all the way through and get some nutserts?
Old 09-16-2022, 10:05 PM #5
Syr4RinNC's Avatar
Syr4RinNC's Avatar
I pretty much expect to snap a bolt on any job i do now. I try to tigthen it an 1/8 turn before loosening I go very slow, really aggressively use lubricants and heat.
Are you able to just leave it and maybe mount the new strap someplace else or just not use that bolt.
Alternatively, if there is any of the bolt sticking out, can you get a vice grip on it? can you hammer a small socket on to it and see if you can back it out that way?
Old 09-17-2022, 07:44 AM #6
Yeah, I have been looking locally for someone to do exactly that, tried emailing a local welding/fab shop, had a feeling they didn't work on vehicles and yep, they do not. I thought of breaking the weld nut loose as an option and dropping in a bolt through the frame (there is an access hole not too far from it) as kind of a last resort option or actually getting a welder to just weld that strap buckle to the frame. At this point in my 4Runner's life, that strap will likely last longer than the vehicle. Or simplest method, ignore it, leave the HF ratcheting strap and check it every so often, replace if needed.
The gas tank strap lines up exactly with that, not too much leeway. There was a small piece of it sticking out and I tried using a hammer and chisel, no go, not enough meat for vice grips.
Actually, here's a picture I forgot I took.
[Help] Broken Bolt Extraction-img_20220912_171056-jpg
Old 09-17-2022, 11:37 AM #7
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
At this point I would try and punch out the welded nut out of the frame with a BFH (Big F...king Hammer) and good punch then drop in a bolt from above.
Attempting to remove the broken bolt again means trying to get the broken extractor out...which will not be easy, there's no drilling it out because it's hardened steel and much harder then a any drill bit, the only way to get it out is using a diamond Dremel bit and grinding it away, if by chance you go this route and get the broken extractor out, drill the bolt again with several drill bits going up in size until you get to the size of the original bolt or slightly bigger and then retap new threads.
2004 Limited V8
Old 09-18-2022, 10:22 PM #8
iamatt iamatt is offline
iamatt is on a distinguished road
New hole and rivnut?
Sent from my Pixel 3 using Tapatalk
iamatt is offline   Reply With QuoteReply With Quote
Old 09-19-2022, 11:55 AM #9
message's Avatar
message message is offline
message is on a distinguished road
message's Avatar
I replaced my tank straps over the weekend and sheared off the bolts in the process despite my efforts to loosen them carefully.
I then used a punch and a large hammer to knock the sheared bolt and nut free inside the frame rail after reverse drill bits and easy outs failed.
As you can access the location via openings in the frame I used a magnetic pick up tool to align new hardware (fender washer + nylon nut + bolt) for the new strap.
I will be doing the same operation for all of the tank skid bolts I sheared off as well.
2011 Limited - TerrainContact A/T & Blizzak DM-V2 - aFe Pro DRY S - AMSOIL Fluids - Woolwax Undercoat - Lasfit Lighting
2004 SR5 V8 - BFG KO2 - Bilstein Shocks & FJ Springs - K&N filter - AMSOIL Fluids - Woolwax Undercoat - Lasfit Lighting
message is offline   Reply With QuoteReply With Quote
Old 09-19-2022, 02:26 PM #10
Mind showing pictures? You sheared off both of them?
Old 09-19-2022, 02:53 PM #11
message's Avatar
message's Avatar
I sheared off the front bolt and most of the tank skid plate bolts. The rear I was able to salvage.
In the picture below I was able to feed a nylon nut, with a magnetic pick up tool, into position over the bolt hole. From there I used my finger to hold it in place and get the threads started. Finally via the square hole I used a box end wrench to hold the nylon nut while I used an impact to drive the bolt home.
[Help] Broken Bolt Extraction-20220919_134746-jpg
Old 09-19-2022, 02:57 PM #12
Nice! Thought you did it the other way (dropped the bolt through the hole inside the frame, nut on the outside). I also sheared off a few of my skid plate bolts, but I'm not going to put it back on, so no biggie on my end. The front skid plate has been off for years due to the same problem.
Old 09-19-2022, 05:07 PM #13
MikeinNH67's Avatar
MikeinNH67 is a jewel in the rough MikeinNH67 is a jewel in the rough MikeinNH67 is a jewel in the rough MikeinNH67 is a jewel in the rough
MikeinNH67's Avatar
This is what I did. Couple whacks with the BFH and a punch and the tack welded nut was gone. Dropped a long bolt through the hole from the inside with a magnetic pickup tool. Attached the strap with a nut and cut off the excess. The rear one was much harder for me as the metal was rusted enough that it broke off the tab. That one took welding.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 09-19-2022, 05:27 PM #14
There are threads in the frame rail too, right? Or does this bolt only thread into that welded nut? My rear one came out fine, fortunately, but do you mind adding a bit more detail on what you had to do? Did that mount (where the gas tank strap bolts to) that attaches to the frame break off or something?
Old 09-20-2022, 04:38 PM #15
MikeinNH67's Avatar
MikeinNH67's Avatar
No, I'm pretty sure the threads are just on the tacked on nut on the inside of the frame. As for mine, the part that's welded to the frame like shown in the picture below, was rusted enough that the whole thing ripped off trying to get the bolt out. I welded on angle iron to replace it.
Imgur: The magic of the Internet
Picture above from thread: Fuel Tank Strap Replacement Tutorial (60+ Pictures)
Mike
03 4runner Limited
bolt , front , replace , snapped , strap
How bad? Broken lbj bolt. TinBucket 3rd gen T4Rs 6 05-15-2017 05:06 PM
broken bolt johnwoo 3rd gen T4Rs 3 10-02-2014 09:58 PM
Broken bolt removal yota-runner General Discussions 5 09-29-2013 11:10 PM
Broken fender bolt mcaz5 3rd gen T4Rs 9 07-25-2013 03:52 AM
Snapped bolt extraction ideas? mcaz5 General Discussions 23 07-08-2013 08:23 AM
