Old 09-21-2022, 03:27 PM #1
Stag_arms402 Stag_arms402 is offline
Stag_arms402 is on a distinguished road
Rear Springs with 5100 Shocks?
I just ordered a complete set of Bilstein 5100 shocks for my 2003 4runner & was wondering what rear springs I should get? I dont want to spend over $200. I will mainly be highway driving & occassionally offroading for hunting/fishing, maybe light towing in the future.
Also I want to have my 4runner leveled out & give it a little bit more aggressive profile. I have 265/70 tires on there now. I was thinking of putting the adjustable shocks @ 1.75" in front & none in rear. Can I see some of your 4runners & the amount of lift you put on your Bilstein 5100s?
2003 White Toyota 4Runner Sport Edition 4X4 V6, JBL Sound System, Hella 500FF, Interior Blue V-LED lights
Stag_arms402 is offline   Reply With QuoteReply With Quote
Old 09-21-2022, 04:59 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
REad through the lift central thread - youll see lots of pictures. Each 4r is slightly different for a variety of reasons so 1.75 on one may look different than another.
Id recommend continuing with a slight rake - consider the 1.25 perch -if youre towing or put weight in the rear you wont be dragging in the rear.
Consider getting someones 5th gen take off springs for cheap / free - this will provide about a 1 inch lift and very slightly stiffer rating. I did this until I started adding aftermarket bumper and other heavier parts to the truck
Old 09-23-2022, 07:42 AM #3
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
im happy with my bilstein b12 springs. Part: 36-281824
theres a guy here selling them, but brand new off amazon was around 200ish.
the guy here listed for 5th gen, but they all fit the 4th gen as well.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 05:53 PM #4
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
I'll try to gat a pic of mine for you, but I have 5100's set at 1.75. I have a 1.5" daystar spacer on the rear springs (IIRC) and I used FJ cruiser springs. They are a tiny bit taller I think. I put 265/70/17 AT tires. Rides totally fine. I kept the factory rake.
I really should get new upper A arms, however, to get back my factory caster setting. My local shop can get it at around 2 degrees, and I notice that it's touchy on the highway. It's not bad, and my wife hasn't complained (that's how I confirm it's not bad) when she drives it. I think you'll find the same thing, but there are plenty of people who report no issues at 1.75. The other thing is I have a set of new lower A arms, so some uppers would allow me to refresh all my ball joints, bushings, etc. Then again, I'm at 278k on the original ball joins and they are nice and tight. I'm paranoid and I'm always expecting both shoes to drop at once and have a front end rebuild to do on my DD (with long work commute, kids to and rom school, etc.). So far the T4R has been super... (the alignment guy at my shop says toyota ball joints last "forever.")
I know several people have posted threads about their lifts and they've had lots of wheel well measurement comparisons. I'm totally guessing that you'll prolly get a couple (3?) inches of clearance between the top of the tire and the wheel well. I'd guess there's certainly room for a larger size, 33 pretty easy. But, Most tend to put wider tires and then there will be rubbing. I didn't want to mess with that. It would definitely look better with a bit wider stance.
2008 SR5 4WD
bob3dsf is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 07:34 AM #5
Hitmanhink Hitmanhink is offline
Hitmanhink is on a distinguished road
I had a rough country 2” spacer lift with bilstein 5100s on stock springs.. it was just enough for 33s but I wanted a little more so I switched out my springs.. I went with Toytec Superflex RCC2.0-P for the rear and Dobinisons C59-314B for the front. I wound up getting about 2” more front and back. Here’s some before and after pics:
Before https://www.dropbox.com/s/0tckttwgda...%20PM.jpg?dl=0
After https://www.dropbox.com/s/ce59ra98bs...81%29.jpg?dl=0
Silver 05’ 4Runner V8 4.7L Sport, Bilstein 5100 shocks, Dobinsons C59-314B front springs, Dobinsons Aluminum Billet UCA’s, Superpro offset LCA’s, OCD sway bar endlinks, Toytec Superflex RCC2.0-P rear springs, Cooper Discoverer A/T 3 285/70/17 tires, SCS Blaze 10 Wheels with -10mm offset, and lots of plans for future mods…
Hitmanhink is offline   Reply With QuoteReply With Quote
4runner , bilstein , rear , shocks , springs
Who's running LC springs and Bilstein 5100 3rd gen shocks in the rear? calnhob 3rd gen T4Rs 63 01-19-2023 03:51 PM
FS: 4th gen Bilstein 5100 rear shocks - $100 - Colorado springs, CO gaara46 For Sale: Suspension/Wheels/Tires 1 12-02-2016 04:39 PM
FS: $350 F&R 5100 adjustable shocks, FJ rear springs, and stock parts South-O 4RnR For Sale: Suspension/Wheels/Tires 5 10-06-2014 12:26 AM
FS- Bilstein 5100 Front and Rear Shocks w/FJ Springs-NJ Scoward For Sale: Suspension/Wheels/Tires 4 08-22-2014 06:16 PM
Front Bilstein 5100 shocks, FJ Springs, And Daystar 1.5" Rear Spacers Installed -Pics man03999 4th Gen T4Rs 39 06-12-2010 11:03 PM
