Old 09-23-2022, 01:40 PM #16
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
Originally Posted by zguy1 View Post
Is there a way to avoid losing a lot of coolant when removing the thermostat and water pump housings? I would like to avoid a big mess and also to keep as much of my coolant as possible since it was recently changed.
Drain the radiator and the engine block and it will help minimize the mess when changing the T-stat and WP out. If you start out with clean buckets/drain pans you could filter the anti-freeze to re-use it but I would rather just start out with new coolant.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 06:20 PM #17
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Originally Posted by phatcheeks View Post
Isnt Aisin the OEM supplier for Toyota? The new Aisin water pump I bought from Rockauto had the Toyota label scratched out.
Yes they are one of them. The question is, are all water pumps for toyota made by Aisin? You might get a different manufactured part when purchased at a dealer.
Aisin is a known quantity/quality.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 09-25-2022, 08:57 PM #18
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
So I spent some time on the truck today. I have the new water pump and thermostat but I have not changed them yet as I couldn't find any leaks by the water pump, pulleys or anywhere on the truck. I even removed the shroud to check the radiator too. The radiator was replaced last year but I wanted to double check.
I proceeded to remove the spark plugs to check them and look inside the cylinders with a small camera. These plugs have been for about 35k miles. I noticed on cylinder #6 that the ceramic was whiter than expected or at least compared to the others. The piston also has some white spotting on it too. All of the other plugs are darker in comparison. Cylinder #4 piston had some white spotting but to a lesser degree. All of the other pistons (5, 3, 1 and 2) looked to be mostly carbon colored. I also noticed oil on spark plug #6 too. #2 had some as well so I am guessing there is a valve cover gasket issue also.
I also tried to use a combustion leak tester on the radiator but it never changed color to yellow.
I have attached the pictures below. I also included a picture of spark plug #6 when I changed the previous plugs at 258k miles. Those plugs were on the truck for at least 52k miles as they were on there when I bought it. You can see the plug looked different then.
Thoughts? Head gasket issue?
Spark plug #6
Spark plug #4
Spak plug #2
Piston #6
Piston #4
Piston #2
Spark plug hole #6
Spark plug hole #4
Spark plug #6 from last charge at 258k miles
zguy1 is offline   Reply With QuoteReply With Quote
Old 09-25-2022, 09:17 PM #19
Drcoffee's Avatar
Drcoffee's Avatar
#6 looks fine. Id be concerned about #4. I havent seen a plug that bad in any toyota I have owned. Thats way too much carbon. I would seafoam the top end and add 1qt MMO to the oil on the next oil change to clean the piston rings. Change your pcv valve. It might be sucking in too much oil
Did you use a vacuum port to draw vapors from the radiator or the squeeze bulb? I was worried about mine when I bought. I ran a vacuum line from the intake to the device and bubbled it for 5 minutes. Still no change to the fluid color. If it didnt change color then you need to keep looking for the leak.
Re-gap the plugs
Old 09-25-2022, 09:26 PM #20
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
#6 piston crown and spark plug look suspiciously clean, usually caused by coolant ingestion. Steam is an excellent carbon remover.
My next diagnostic step would be renting a cooling system pressure test kit from Autozone/Advance Auto and pumping it up to the cap's rated pressure. A head gasket will drop pressure slowly and steadily as soon as you stop pumping.
Are you having any rough engine idle on cold startup and/or hearing gurgling/waterfall noises from the dash (heater core)? These are often reliable indicators of head gasket failure when combined with coolant loss.
waypoint is offline   Reply With QuoteReply With Quote
Old 09-25-2022, 09:42 PM #21
zguy1's Avatar
zguy1's Avatar
Re-gap the plugs
I was supposed to leave on my road trip today but wanted to check a few things before I headed out with the truck. The pcv was changed in 2020 or about 36k miles ago. I only have 3100 miles on the current oil and was planning on changing it before going as I will be putting about 2500 to 3000 miles on it during my road trip. I have never used seafoam or MMO. I guess I could try both.
With regard to the combustion tester, I removed the radiator cap and warmed up the truck. I kept the coolant below the neck by about 2" or so by siphoning it out while it was warming up. I put the tester on top of the radiator and used the squeeze bulb. It was an imprecise test as the test tool does not seal around the sides so I tried to keep it flush along the bottom edge.
It looks like I am still going to take the truck, albeit I am a bit nervous. I am willing to try a few more things tomorrow so I could leave Tuesday AM.
Old 09-25-2022, 09:47 PM #22
zguy1's Avatar
zguy1's Avatar
I can rent a cooling tester tomorrow and give that a try.
I was thinking about changing the radiator cap but not if that is warranted. I never replaced it before even when I changed the radiator in 2020.
I do not hear any noises from the dash. The car runs great and has never set the check engine light as long as I have owned it.
Old 09-26-2022, 07:50 AM #23
Drcoffee's Avatar
Drcoffee's Avatar
When the head gasket fails, it allows pressurize gasses into the cooling system. This forces coolant into the resevoir and it overflows to the ground. What you would see is an empty resevior which it does not seem to be the case.
The head gasket could be leaking beteen the head and block. You would see crusty pink somewhere on the engine.
Otherwise its leaking from a hose or maybe the heater core.
This is how mine looked at 220,000 (orig plugs). Some are cleaner than others. Notice the gap sizes, and it still ran pretty good.
Lastly, yours is a 2008 which means its beyond the timeframe where the head gasket failures were typically seen. Id take the trip and not worry about it.
Another coolant loss thread.  Advice needed...-d18dcf28-3d7c-4c30-8b87-b48fa6acf02c-jpg
Old 09-26-2022, 08:15 AM #24
Drcoffee's Avatar
Drcoffee's Avatar
Where you see the pink crust by the t-stat is an odd place to have it. Thats the oil filter housing. There are some small hoses below the thermostat housing that could be the source of you leak. You will see them once you do the water pump.
Old 09-26-2022, 08:56 AM #25
OopsIBrokeIt OopsIBrokeIt is offline
OopsIBrokeIt will become famous soon enough
I just went through similar in the last couple weeks. I first spotted some crusties up near the throttle body and thermostat, but was unable to identify any leaks.
A few days later I noticed a semi regular drip of coolant under the car at idle and went looking, it was the water pump leaking and the serpentine belt flinging coolant around the bay from there.
I went ahead and replaced pretty much all the hoses just as insurance, but most were still in decent shape for being original.
OopsIBrokeIt is offline   Reply With QuoteReply With Quote
Old 09-26-2022, 11:23 AM #26
zguy1's Avatar
zguy1's Avatar
I'm planning to take the trip at this point. I may pick up a new set of plugs from the dealer even though these are relatively "new" compared to the ones I took out when I bought the truck. Yesterday, when I was using the combustion tester and was finishing up, I revved the truck with the radiator cap off and coolant came out. I assume that was from the water pump pushing coolant through the system as opposed to exhaust gases escaping.
Where you see the pink crust by the t-stat is an odd place to have it. Thats the oil filter housing. There are some small hoses below the thermostat hosing that could be the source of you leak. You will see them once you do the water pump.
Right, I will hopefully know more then I remove the water pump and thermostat when I get back.
Old 09-26-2022, 11:25 AM #27
zguy1's Avatar
zguy1's Avatar
Aside from that tiny bit of crust, everything is bone dry that I can see. Maybe more will be revealed when I do the water pump eventually.
Old 09-26-2022, 04:12 PM #28
Do you see any stains or water marks on the serpentine belt? That was part of how I identified the WP as the probable source of my leak.
Old 09-26-2022, 04:41 PM #29
zguy1's Avatar
zguy1's Avatar
Leak found and it's not good news...
Well, I was able to get another inspection camera with the ability to see from the side. I also rented a cooling system pressure tester. I pumped up the system to 13 psi. I could not see any leaks and the pressure held steady.
I went ahead and pulled the spark plug from cylinder #6 and started looking around at the gasket area in the cylinder with the camera. I saw an area that looked questionable and a bit wet. I proceeded to wait and after about 5 mins I saw a single droplet form from the head gasket area and roll down the cylinder wall. The drop appears every 5 or 10 mins but that is under 15 psi.
I know I have been driving like this for sometime but I can't knowingly take this truck on a road trip with a fully of gear with the risk of breaking down. Most shops can't fix it and dealers will charge a fortune. I also don't know what else is wrong. Could the head be warped? It never overheated while I owned it but that is too much to risk on the road.
2008 V6 4Runner with 295,221 miles.
[IMG][/IMG]
Old 09-27-2022, 12:00 AM #30
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Thanks. I can't wait for Rock Auto parts so I was able to find a Toyota water pump and ASIN thermostat at Amazon that I could get in 1 day. The Toyota water pump is about $25 cheaper than my local Toyota dealer.
Any recommendation on brand and parts for pulleys?
Why? Are any of those parts leaking your coolant?
Seymore Butts is offline   Reply With QuoteReply With Quote
check , coolant , miles , past , replace
Loss of Coolant PLDXSR5 3rd gen T4Rs 9 03-09-2018 04:24 PM
Coolant leak. Advice needed 46runner 4th Gen T4Rs 7 05-09-2017 12:23 PM
Wreck caused "Total Loss" - Insurance advice needed please! Trik444 General Discussions 36 03-24-2017 05:40 PM
Coolant loss NegroTundra 3rd gen T4Rs 12 11-08-2016 09:00 PM
Advice needed for coolant/radiator issue chadsy 3rd gen T4Rs 2 09-18-2013 02:13 AM
