Old 01-23-2023, 02:11 PM #16
twa318 twa318 is offline
twa318 is on a distinguished road
Originally Posted by Boort View Post
@88skisupreme @stompbox1791
One on my 06 battery died a few months ago. So far Black tape on the dash for me. My scanguage tells me that it's TPMS #4 that has died though I have no clue which tire that is . All 5 are full so I just pull out the trusty wand and make sure they stay that way same as I have for all of my other rigs since I learned to drive.
I'll leave it that way till either I get enough time to bother with the TPMS bypass done by others on this forum (See: Write-up: How to Disable (Bypass) the TPMS or 2008 TPMS bypass ) or I need to have the tires removed from the rims for another reason when I'll have new ones put in. Which ever comes first. The bypass is likely MUCH easier than pulling the dash to remove the bulb. Though given the prevalence for the bulbs in the rest of this rig's dash and AC controls to go out it may just burn out from being on then you don't need to worry about it. ;)
Boort
Black tape on the dash is an ugly and lazy solution.
It literally takes 5 minutes to bypass the TPSM using the instructions you linked in your post. It probably took longer to type your post reply then it would have to bypass the TPSM.
Simply jump the wires with a small paper clip and the light is gone forever.
Here I even took the time to direct link the post with image for you:
https://www.toyota-4runner.org/1848689-post75.html
Just do it already it couldnt be any easier
'99 SR5, 2007 Sport
twa318 is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 09:05 PM #17
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
@twa318
I hear ya. It is on a long list of <20 min tasks I need to do that I have not gotten around to knocking out.
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 10:29 PM #18
Juice88 Juice88 is offline
Juice88 is on a distinguished road
4 of my 5 sensors are shot in my 08. I was quoted around 1 grand for replacement at dealership (no thanks). Luckily its covered under the extended warranty I bought, so I'll be getting them all replaced. But ive been driving with the light on for almost a year now
2008 V8 Sport 62k miles
Juice88 is offline   Reply With QuoteReply With Quote
Old 01-24-2023, 01:30 PM #19
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
but what type of clip (color, material, length, thickness??)! regular steel, stainless, plastic coated, etc...
need answers!
rwh963 is offline   Reply With QuoteReply With Quote
Old 01-24-2023, 03:21 PM #20
need answers!
Reach into your junk drawer, pull out the smallest paperclip you can find and it will do the trick.
I did not disconnect the battery.
'99 SR5, 2007 Sport
Old 04-06-2023, 01:20 PM #21
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
need answers!
Don't use a f_cking paper clip. Use the proper gauge wire and appropriate connectors. The same type of wire your jumping. We've talked about this before. I did this tpms bypass also. If you want to get cool results add a switch to your jumper wire. That way you can enable or disable the system if you ever fix the sensors. Nice if you air down off road a lot to turn off that dummy light. The switch installs in one of the blanks on the dash. I got a perfect fit switch from Napa for like $5. It doesn't take any extra work or time.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 04-06-2023, 02:05 PM #22
Forum148 Forum148 is offline
Forum148 is on a distinguished road
I would and did bypass them super easy process and also easy enough to check your tire pressures.
This is how I did mine. It’s been bypassed for years no issues and is totally reversible if you ever needed to go back
https://www.toyota-4runner.org/3350475-post13.html
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
Forum148 is offline   Reply With QuoteReply With Quote
passing , replace , replacing , sensors , thinking
When to replace TPMS? philsey 5th gen T4Rs 27 04-07-2023 03:46 PM
Repair head gasket, replace engine, or replace truck? backcountrylimo 3rd gen T4Rs 31 10-01-2020 12:45 PM
Replace ITRs or replace steering rack. johnbyebye 3rd gen T4Rs 8 09-15-2017 08:09 PM
need to replace o2 sensors.. where to go yotamandan 4th Gen T4Rs 7 01-26-2016 08:30 PM
Replace cat converters or O2 sensors? Warranty issue or not? Also need pics pls. atomic punk 4th Gen T4Rs 21 09-11-2011 09:22 PM
