Old 09-25-2022, 10:25 PM #1
matthewkristof's Avatar
matthewkristof matthewkristof is offline
matthewkristof is on a distinguished road
Weird Electrical Issue
Original 07 Sport owner here, 255k miles in the rig. Got an odd electrical issue that I can really put my finger on.
Sometimes at startup, the runner will do a quick hiccup; this usually involves a flicker of the dash lights then the car fires up. The rear window wiper will also go, even though the stalk is in the off position.
I changed the starter about 5k miles ago. I haven’t done anything in the car lately other than change some climate change bulbs. Maintenance over the fifteen years has been normal and nothing major. No codes when running hooking up an OBD2 reader.
Kinda at a loss. Any help would be appreciated. Thank you!
2007 SE, Galactic Grey Mica - original owner
Mods/Upgrades: Oh Crap Handle on driver's side, Hilux Surf Trash Stash, Amber Colored Auto-Dimming Mirror w/compass, USB ports using 115V switch, LED interior, Weathertech Digital Floor Liners, Homelink Garage Door Opener, Footwell Lighting, Automatic Headlights, Dual Cargo Organizers, Maplight Mod, Morimoto 5k HID Low-Beam and Fogs, LED exterior, 15% 3M tint, AVIC-6100nex, Pioneer speakers (TS-G1345R, TS-G1645R, TS-T110), Limited Grill, Mini Backseat Organizer, Heated Cloth Seats, KO2s
matthewkristof is offline   Reply With QuoteReply With Quote
Old 09-26-2022, 03:33 AM #2
Kevin G. Kevin G. is offline
Kevin G. is on a distinguished road
Pretty sure the battery is starting to go bad. The rear wiper system is resetting due to voltage drop at startup.
Check the battery cranking voltage.
Hope this helps.
Kevin
Kevin G. is offline   Reply With QuoteReply With Quote
Old 09-26-2022, 05:42 AM #3
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
The rear wiper coming on is sure sign of a bad battery as mentioned.
2004 Limited V8
Old 09-26-2022, 09:43 AM #4
Thank you for the replies. Battery was just replace by Toyota in June so I’m pretty shocked it’s dying so quickly.
Does not driving it everyday affect battery life? It’s no longer my daily driver but still driven 3-5 times per week, minimum.
Old 09-26-2022, 10:14 AM #5
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of
Bluesky 07's Avatar
What about the alternator? Has it been replaced? My original alternator recently died at 229K. A bad one can take the battery with it.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 09-26-2022, 11:28 AM #6
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
The first two diagnostic tests in your case:
Battery voltage with engine off, after the car hasn't been started for at least 12 hours. Longer would be better.
Charging system voltage with engine running, measured at the battery. (should be between 13.2 and 14.2)
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 09-28-2022, 08:42 PM #7
Tested the battery after no driving for over 36 hours. Cold start. Voltage hovered around 12.33.
Started car and let it run for a few minutes. Voltage hovered around 13.73.
Given that my alternator has never been changed, and that this battery is three months old on with 255k+ miles, looking like the alternator is the culprit.
Old 09-29-2022, 03:11 AM #8
Measure the voltage WHILE CRANKING.......NOT while sitting off, or engine running.
Your may need a recording voltmeter, such as a Fluke 87.
Hope this helps.
Kevin
Old 10-02-2022, 01:28 PM #9
caninerelated caninerelated is offline
caninerelated is on a distinguished road
I too have weird electrical issues. Driver side window has no power. Power to all other windows. I've changed out the master switch as well as the regulator and motor. I'm stumped. Super frustrating not having power to that window. Any suggestions?
Sent from my CLT-L04 using Tapatalk
caninerelated is offline   Reply With QuoteReply With Quote
car , change , electrical , issue , miles
Weird electrical issue Ctullu 4th Gen T4Rs 0 11-01-2020 02:07 PM
Weird electrical issue on 2015 Trail Ezekiel2222 5th gen T4Rs 113 01-10-2020 05:23 PM
Weird Headlight/Electrical issue stf5060 3rd gen T4Rs 1 01-09-2020 11:01 PM
Weird electrical issue with fog lights zopperman 4th Gen T4Rs 4 03-20-2013 09:16 PM
Weird Electrical Problem Badbob Classic T4Rs 3 01-07-2013 08:09 PM
