Old 01-29-2023, 02:00 PM #16
Pale Rider Pale Rider is offline
Pale Rider is on a distinguished road
Anybody have an idea why I wouldn't have an ignition relay??
According to the diagram it should be in the upper right corner right above the Defog relay.
Intermittent Starting Issue-4runner-fuse-box-jpg
2006 V6 SR5
Pale Rider is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 07:25 AM #17
daletehbest's Avatar
daletehbest daletehbest is offline
daletehbest is on a distinguished road
With you having checked so many of the other ancillary items, I would make sure all ground connections are good. You could take a wire brush and go over connections to ensure no oxidation issues are causing a problem.
Just a thought, I know that a grounding issue can present itself in different ways. But it costs nothing to wire brush a few connections and reinstall
Remove the ground. Ensure a metal on metal connection and the absence of corrosion, and then reinstall
2008 V8 4Runner 4x4
2010 Rav4 V6 4x4
2013 Corolla S
daletehbest is offline   Reply With QuoteReply With Quote
Old 02-04-2023, 05:43 PM #18
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
I just checked my '07 Limited, it has a big gray relay in that slot. Same relay as the HEAD relay if you feel like swapping yours. Unless somebody broke in and stole your IG relay, however, I'd say this isn't your problem.
waypoint is offline   Reply With QuoteReply With Quote
Old 03-01-2023, 08:39 AM #19
Update
Turns out it was the neutral safety switch.
Mechanic said there was a lot of corrosion on the contacts of the old neutral safety switch and that it was difficult to remove.
New OEM switch is installed and the truck has started every time since I've had it back, which has been three weeks ago.
Would like to thank everyone for their advice and suggestions for helping me troubleshoot this problem.
2006 V6 SR5
friday , issue , key , start , time
Need help - intermittent starting issue. Luciendar21 3rd gen T4Rs 12 05-17-2019 12:17 PM
85 22re with intermittent starting/stalling issue blackchild Classic T4Rs 25 06-07-2017 03:59 PM
Intermittent starting mndanielsncsu 4th Gen T4Rs 8 02-12-2014 08:36 AM
Intermittent starting issue dangros 4th Gen T4Rs 5 02-21-2012 09:52 PM
Intermittent Engine Starting/Running Issue TheSpeakGeek 4th Gen T4Rs 4 12-04-2010 08:48 PM
