Originally Posted by 08tnt
Recently my 4 runner gauge will ready empty with the light on even though it has gas in it. Level does not matter. I did hit the mode button just to see and it read like it should so, think the gauge is the problem? It comes and goes. Need some input please.
2008 4 runner limited V-6 2 wheel drive
If I read your post correctly, when you hit the "mode" button all the info is correct for the amount of gas you have in the tank, if so that tells me the fuel sending unit in the tank must be working correctly, so the issue is in the gauge itself....so my guess is the "stepper" motor, which there are 4 of on the instrument cluster circuit board, one for each gauge in the cluster, has gone bad, they can be replaced but they are soldered on the circuit board, if this is the issue you have 3 options, replace the motor/s yourself, send your cluster in too a specialty shop that does this kind of work to have them do the repair....or get a new/reman/used cluster from the aforementioned specialty shop, or savage yard which has to be for your exact year and model T4R.
Here's a link to a topic on the stepper motors subject.
Dashboard gauge needles not working or showing incorrectly -- FIX
The next link is too a site for buying new stepper motors, a rebuilt cluster or having your's rebuilt.
The owner of this site is also member here
TaninAuto
and has posted a discount code that may still work for 10% off....
"We have a discount code for the 4Runner forum, you guys get 10% off with code "4RUNNER10"
You searched for - Tanin Auto Electronix
