Old 10-05-2022, 11:28 AM #1
SR502JAI SR502JAI is offline
SR502JAI is on a distinguished road
Operating coolant temps after burping coolant system
I have an 04 4runner v6 4x4 w/192k that I replaced the Evap Core due to it leaking, I didn't replace the heater core because it was still in pristine condition with no veins or fins damaged. I reinstalled everything and went with ZEREX RED instead of the Toyota pink. I filled the coolant and burped the system, now with the car at idle is at 185*F and about 186.6 to 190.4 while running with A/C or without A/C at an ambient temp of about 92*; I get my readings through my torque app pro. I remember before the repairs the car was running at 175*F to 180* with or without the A/C on. Is it possible that the cooling system still has air pockets? I'm looking too much into this? Or am I just causing my self to be paranoid with the coolant temps? Any help or feed back is appreciated
2004 4RUNNER SR5 4WD STRATOSPHERIC MICA BLUE / TRD GRILLE WITH GRILLE LIGHTS / XTRONS ANDRIOD HEAD UNIT / STAGE 2 IRONMAN 4X4 FOAM CELL PRO SUSPENSION LIFT / TOYO OPEN COUNTRY AT3S / EBAY ROOF RACK/ MORE TO COME!!
SR502JAI is offline   Reply With QuoteReply With Quote
Old 10-05-2022, 11:38 AM #2
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks has a spectacular aura about phatcheeks has a spectacular aura about phatcheeks has a spectacular aura about
phatcheeks's Avatar
I have an 04 V6 as well. My temp are usually at 182-190 for normal city driving. I will get 193-195 at highway speeds or hard pulls.
175-180 seems low since the thermostat opens at 182 I believe.
I think you should be fine.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker. PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 10-05-2022, 12:20 PM #3
Thanks for the input @phatcheeks I appreciate the response, I just want to make sure that its running in tip top shape and do not want it overheating since I will be hitting some dessert trails this weekend.
Old 10-05-2022, 03:12 PM #4
OopsIBrokeIt OopsIBrokeIt is offline
OopsIBrokeIt is on a distinguished road
I just replaced damn near everything. WP, Radiator, most of the coolant hoses, thermostat, and the slightly higher pressure TRD radiator cap and I'm averaging 180-186 in normal use with or without AC. A long highway trip with AC in Texas summer heat got me up to about 190 and relatively quickly back down once I stopped moving.
I do also have an secondary transmission cooler to help manage those temps, so maybe that's helped remove a heat source as well.
OopsIBrokeIt is offline   Reply With QuoteReply With Quote
Old 10-05-2022, 09:04 PM #5
While driving to the store today for some reason i was tempted to feel how hot the rad hoses where and found the top hose very hot and the lower hose to the thermo stat cool. Is that an indication that the thermostat is bad? Or that there is still air in the system? Or is that how it should be?
Old 10-05-2022, 09:19 PM #6
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all
rdruss's Avatar
Real Name: Ron
Assuming the lower hose is "radiator out" it should be cooler than "radiator in/engine out", the radiator cools the coolant and thus the rad out hose should feel cooler.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 10-05-2022, 09:37 PM #7
Okay that makes sense. Hypothetical question: the reservoir has coolant to the full line. If after driving it one day, i park it and lets say the next day i see the reservoir low before i leave work, is that normal?
Old 10-06-2022, 08:32 AM #8
If you just refilled the system and are still working to remove air pockets, maybe. If it happens regularly or you didn't just drain & refill it and you're either burning it (head gasket) or leaking it somewhere.
Old 10-06-2022, 10:17 AM #9
phatcheeks's Avatar
phatcheeks's Avatar
Yes that's normal. When coolant gets hot it expands and goes into the reservoir. When it cools down it gets sucked back into the cooling system thus showing a lower level in the reservoir.
If thats not happening and the level keeps dropping or the reservoir is over flowing then you have an issue.
Old 10-11-2022, 01:43 PM #10
Just thought I should update, I was more than likely over thinking the whole coolant issue. Since the fix I have ran my 4Runner and the temps stay between 185* and 190.4 depending on the weather, it does not go passed 190.4* even with the A/C on. I did my spark plug change last week, it seems to be the 3rd time my 4Runner has ever seen a spark plug change since last know change was about 11 or 12 years ago, no lie. I checked the cylinder walls with a borescope and found the cylinders to be in great condition for 192,950 miles. No coolant or white visible at all. Thank you all for your help!
a/c , car , coolant , system , temps
High Coolant Temps 4x4mike 4th Gen T4Rs 14 07-08-2022 01:04 PM
Normal coolant temps cj80cruiser 3rd gen T4Rs 160 12-29-2021 02:53 PM
Engine Coolant and Trans Temps DMX512 4th Gen T4Rs 17 12-27-2019 07:36 PM
temps, air intake, and coolant temps on a stock runner the great him 3rd gen T4Rs 13 07-15-2014 10:18 PM
Normal Coolant/Trans temps? tenro1 3rd gen T4Rs 10 04-03-2014 11:54 AM
